302 redline? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2011, 09:06 PM   #1
eagle-eye
Default 302 redline?
What is the fastest rpm a stock 302 can be run up to?? its a truck motor...
eagle-eye is offline   Reply With Quote
Old February 27th, 2011, 09:07 PM   #2
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
Rockstar is offline   Reply With Quote
Old February 27th, 2011, 10:02 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Depends on a few variables, but it can range from 5500 to 6500, although they typically peak (power-wise) around 5800-6100rpm, depending on year.
Old February 27th, 2011, 10:04 PM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i would keep it under 6000
H.o.r.e
Old February 27th, 2011, 11:07 PM   #5
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
i would try 5500 1st then try working up to 6000 6100 62000 ect.. not all motor a built the same..
Old February 27th, 2011, 11:23 PM   #6
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
mine peaks around 5,500 id say..
84mudder is offline   Reply With Quote
Old March 1st, 2011, 06:12 PM   #7
Tacker
Tacker's Avatar
6000 is a good number
Old March 8th, 2011, 11:21 AM   #8
lovebite
BAMF
lovebite's Avatar
It also depend on what type of lifters you are going to run and if they are hydraulic what kind of quality: old, new, brand.
lovebite is offline   Reply With Quote
Old March 8th, 2011, 11:26 AM   #9
90Notch306
90Notch306's Avatar
If it is a stock motor then you aren't making any power past 5000
90Notch306 is offline   Reply With Quote
Old March 8th, 2011, 07:57 PM   #10
eagle-eye
stock motor, and i have a tach. at full bore the rpms peak at about 4500. how do i change this in an obd1 type vehicle?
Old March 8th, 2011, 11:02 PM   #11
90Notch306
90Notch306's Avatar
Do you mean it wont rev past 4500?
Old March 8th, 2011, 11:08 PM   #12
bdd1469
bdd
bdd1469's Avatar
Weld lobes back on cam? Um ya.lotsa reasons it wont rev,plugd convertor?free rev or under power?
Old March 11th, 2011, 02:38 PM   #13
mfelsk1505
AMSOIL DEALER
mfelsk1505's Avatar
my bronco loves to be around 4500
mfelsk1505 is offline   Reply With Quote
Page generated in 0.27860 seconds with 62 queries
