armor questions. detachable? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2011, 08:00 AM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default armor questions. detachable?
so i'm going to try to explain this the best i can.
i'm doing some armor on my tj.
i want to have a small stinger and a headlight surround,wich will tie to the bumper/frame.
off of the suround ( 2 o'clock on the driver side headlight and 10 o'clock on the passanger side headlight) i want to start my fenders . flat fender/tube style not the stock ones.
the problem is i want to be able to remove them. not just burn them in.
anyone else do this or have pics? what did you use to tie them in.
i was thinking , to use a sleeve of smaller tube to fit in side with two small oval plates to bolt them together. thoughts?
thanks aron
luvitmyjeep is offline   Reply With Quote
Old February 27th, 2011, 07:34 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
http://www.summitmachine.com/store/i...mps/index.html
Old February 28th, 2011, 09:15 AM   #3
jimmyroyse
webwheeler
jimmyroyse's Avatar
maybe something like this?
http://diy4x.com/cart/index.php?rout...&product_id=99
jimmyroyse is offline   Reply With Quote
Old February 28th, 2011, 11:31 AM   #4
Originally Posted by Jeeperz Creeperz View Post
This is what I used.
Old February 28th, 2011, 06:25 PM   #5
luvitmyjeep
broken
Originally Posted by jimmyroyse View Post
yes. but with a longer sleeve/pin. thanks
Old February 28th, 2011, 06:29 PM   #6
luvitmyjeep
broken
would i have to twist turn my whole fender or just unbolt it?
Old March 1st, 2011, 09:12 AM   #7
Depends on the orientation you put them when you weld them in. Mine unbolt from the body side(4 stock bolts) then unbolt the tube clamp and remove straight up. How yours come apart will be determined by how you attach the tube clamp and the orientation of it when you weld it in.
Old March 1st, 2011, 11:06 AM   #8
luvitmyjeep
broken
ahh i see. it looked like they needed to turn to fit togeather. thanks
Page generated in 0.27399 seconds with 47 queries
