lifting my k1500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2006, 08:42 PM   #1
Slayer63
Upstanding Member
Slayer63's Avatar
Default lifting my k1500
i have a 95 silverado k1500 and i want to lift it. im too poor for a suspension lift so im gonna crank up the t-bars. from what i hear i could get 2 inches of lift from the stock keys and then put blocks on the back. is this gonna work? i still have to drive it on the road and with that much lift, i was wonderin how big of tires i could go with the stock wheels. help?
Slayer63 is offline   Reply With Quote
Old September 1st, 2006, 10:54 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
It'll work but if the mney you'll spend in balljoints and front tires a Suspension lift would be cheaper in the long run...
Old September 2nd, 2006, 08:55 PM   #3
Slayer63
Upstanding Member
Slayer63's Avatar
what if i put ford keys on it?
Old September 3rd, 2006, 11:20 PM   #4
Symmes
U can fit 285s on it stock. I have a 95 tahoe and it sat super low before, i went to discount tire and they said that you can fit 285s with easy, and they were right and i dont rub a single bit.
Symmes is offline   Reply With Quote
Old September 3rd, 2006, 11:22 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
Just remember if you crank your torsion bars, you no longer have that 2 inches of downward wheel travel.
Old September 8th, 2006, 02:06 PM   #6
shredder70
Chillin with the top off.
shredder70's Avatar
If you want a cheap lift for tire clearance you can get a 3" body lift for about $150.. And 3-4 hrs of install time, than you can clear 33" tire no problem..
shredder70 is offline   Reply With Quote
Old September 12th, 2006, 06:56 PM   #7
Slayer63
Upstanding Member
Slayer63's Avatar
so a two or three inch body lift would be better than just cranking the bars? i mostly just mud but its also my street ride and im runnin 265 A/Ts right now and i tend to bottom out.
Old September 12th, 2006, 09:34 PM   #8
Symmes
URr bottoming out with 265s? I would say go with 285s and crank the torsion bars if you have to a little bit. Becasue ive never rubed with my 285s.
Old September 14th, 2006, 07:45 AM   #9
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
don't crank the t-bars. I did and i'm getting some binding and noise from the front end at times. if you're bottoming out then you need new shocks or a new suspension. my truck was hard enough to keep aligned before i cranked the tbars, now it's impossible which is causing the tires to wear a little unevenly. if you're serious about the mudding you do then just save up some cash and either do the body lift or a suspension lift. if it were me, i'd wait till i had cash for the latter of the two.
BigBlueBurban is offline   Reply With Quote
Old September 14th, 2006, 05:07 PM   #10
biohazardbill
The Biohazards
biohazardbill's Avatar
As for daily driving I am dring my 92 GMC on 38's daily...
7 inch suspension lift, 3" body..
biohazardbill is offline   Reply With Quote
Old September 14th, 2006, 07:44 PM   #11
stockhoe
You can safely crank about 1.5 inches without many problems. I would do that and a body lift with a 33 or 35 inch tire depending on if you want to stuff or not. As for rubbing 285's I do with 1.5 inches of crank and 1.5 inch block in the back.
stockhoe is offline   Reply With Quote
Page generated in 0.24500 seconds with 56 queries
