help 95 s-10 bazer t-case no shift, electronic - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2005, 08:22 PM   #1
Tonka
Tonka's Avatar
Default help 95 s-10 bazer t-case no shift, electronic
My mom has a 1995 s-10 blazer.
She's having issued with the 4wd.
It has new switches, that have been tested and are good.
all I get is ckicking from the module behind the dash. and the 4hi nd low lights will flash and both stay on......
I'm looking for where to start looking for issues.
Old December 8th, 2005, 09:46 PM   #2
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
look into the shift motor, its a fairly comon problem. same thing happened to me. it has a circuit bored on it so the switches will click and try to send the message but the motor wont shift
GMCsonoma94 is offline   Reply With Quote
Old December 8th, 2005, 10:26 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
same thing happened to me and the whole t case was bad
Old December 8th, 2005, 10:44 PM   #4
Chop
Mischievous Badger
Chop's Avatar
big X2 to that one
Old December 9th, 2005, 11:38 AM   #5
Tonka
Tonka's Avatar
Thanks Guys! I'll look into it later today.
Normally I'd just tear into something and figure it out, but It's my mom's, and I don't want her to have to be stuck home.
Old December 9th, 2005, 12:05 PM   #6
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Im not positive of it, but didnt the electronic shift t-case s-10s still use a NP231, if so maybe there is Ice jamming up the linkage to the shift motor...
Old December 9th, 2005, 01:45 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
theres no external linkage. the motor mounts right to the case
Yetti
Old December 9th, 2005, 01:47 PM   #8
Yetti
Yetti's Avatar
http://www.photodump.com/viewer/Yett...ble-codes.html
Yetti
Old December 9th, 2005, 01:58 PM   #9
Yetti
Yetti's Avatar
http://www.photodump.com/viewer/Yett...e-codes-2.html
Yetti
Old December 11th, 2005, 12:16 PM   #10
Tonka
Tonka's Avatar
Thanks Yetti!
Old February 13th, 2006, 11:21 AM   #11
KaiserJeep
boogidy boogidy boo
KaiserJeep's Avatar
if you did not figure it out my guess would be the vacume acutator under the battery. My 1996 did the same thing and the acutator was shot. I replaced it and it works like a champ now.
KaiserJeep is offline   Reply With Quote
Old February 13th, 2006, 03:44 PM   #12
Yetti
Yetti's Avatar
thats just the front axle actuator, it has nothing to do with the flashing lights in the dash for the electronic shift 4x4.
Yetti
Old February 14th, 2006, 10:48 AM   #13
KaiserJeep
boogidy boogidy boo
KaiserJeep's Avatar
aight, well when my acutator went out, the 4x4 light flashed on the dash to tell me, "Hey, don't do anything stupid, you don't have 4x4" I checked the motor, fuses, etc and all was good. I replaced the acutator, light came on steady and I had 4x4.
Old February 14th, 2006, 12:51 PM   #14
GMCsonoma94
1 wheel peel
the light will flash untill then axle and t case are ingaged, but tonka has 2 lights flashing where you only had 1 im assuming. i had the same exact thing as tonka, where it flashed both high and low because it couldnt get anything to work.
Page generated in 0.40250 seconds with 65 queries
