93 ford, runs rough and smokes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2011, 06:00 PM   #1
mudrunner456
mudrunner456's Avatar
Default 93 ford, runs rough and smokes
Driving along the other day and my ford started to misfire. Now it has a miss whether its idleing or cruising. Seems low on power. The exhaust also stinks but i dont know like what. never smelt it before. So im at a loss. Could in be the cat. converter or you think the motor is toast. its a 93 f-150 5.8 liter with a 100,000 miles.
mudrunner456 is offline   Reply With Quote
Old February 21st, 2011, 06:02 PM   #2
Freak
Wheelin the HD
Freak's Avatar
Has a tune up been done? O2 sensor? Got a code?
Old February 21st, 2011, 06:12 PM   #3
mudrunner456
tune up has been done. plugs wires air and fuel filter. ran great after that last week. then it started this on friday. No code, and i dont know about the 02. like i said im at a loss just lookin for some ideas, i will take it to a shop soon if i cant figure it out.
Old February 21st, 2011, 06:15 PM   #4
Freak
Wheelin the HD
Freak's Avatar
Check your connections on the plug wires, you might have a lose one, I had one pop lose 2weeks after a tune up.
Old February 22nd, 2011, 02:52 AM   #5
charliedog
SHOCK-N-SHAW
Pull the spark plugs and look at them. It sounds like a blown head gasket to me. Is it white smoke?
charliedog is offline   Reply With Quote
Old February 22nd, 2011, 05:13 PM   #6
mudrunner456
no white smoke, it is blue smoke. and i just did the plugs 3 days before this happend.
Old February 22nd, 2011, 05:19 PM   #7
94cherokeemike
IT'S A XJ THING
94cherokeemike's Avatar
my 97 f250 5.8l 160k is doing the same thing check your fuel pressure that was my problem
94cherokeemike is offline   Reply With Quote
Old February 22nd, 2011, 05:51 PM   #8
mudrunner456
ok will do thanks
Old February 22nd, 2011, 10:51 PM   #9
tonkatruckon44s
tonkatruckon44s's Avatar
sounds like either a piston ring failing causing oil to go into the cylinders even the smallest leak will cause blue smoke also, doesnt make much sense other than the backfiring but too much fuel. also this could be caused by a bad egr valve. you can either take the egr valve, which is pretty simple to test, take it off and take it to your local auto parts store and have them do a vacuum test on it .that will tell you a lot. then you take and clean the egr valve with carb cleaner on the metal part only. also check the plug wires and everything check and make sure your distributor it tight and didnt come out of time.
tonkatruckon44s is offline   Reply With Quote
Old February 23rd, 2011, 08:29 AM   #10
Quiefinator
go'til itsounds expensive
Nothing against your mechanical ability but i wouldn't rule out any of the things you just changed. Trouble 3 days after maintenance might not be coincident?
You have a few good leads here already. You should be able to tell by looking @ a fresh plug to see if you are burning oil or coolant. Compression test could help verify this too.
Clogged cats can do wierd stuff with power loss as well.
Old February 23rd, 2011, 06:27 PM   #11
mudrunner456
thanks for all the help, dropping it off at a shop tomarrow night. to cold out to work on it myself.
Old February 25th, 2011, 02:02 AM   #12
tonkatruckon44s
also check for vaccum leaks that could cause the running rough, misfire not sure.
Page generated in 0.25246 seconds with 59 queries
