Sfa - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2005, 07:31 PM   #1
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
Default Solid front axle swap
ok i got a 92 suburban and it looks like im goin to have to get a new axel. im thinkin about throwing a D44 under it and a couple inches of lift. its still my DD so im not goin hugh with it. im only goin to run some 33s on it. ride quality isnt a concern to me. so i was wondering if anyone has any pics of cleanly done SFA swaps on full size chevys. im wanting to see some pics of the mounts. i want to make some mounts that i wont have to worry about. for springs i think ill use some 3/4 ton springs from the front of an older suburban. im not going to throw a D60 under it cause that will cost more than i payed for the truck.
GMCsonoma94 is offline   Reply With Quote
Old December 8th, 2005, 08:20 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
whats wrong with your axle ?? why not just swap in a new center chunk for the IFS.. that would be even cheaper i would think
Old December 8th, 2005, 10:47 PM   #3
Chop
Mischievous Badger
Chop's Avatar
his steering is messed up he wants a d44 drivers drop because its simple and easy to fix. and no more IFS for ryan
Old December 8th, 2005, 11:47 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
ok well it's your truck do what u want... anyway here's my suggestion.. make a front crossmember weld that to the frame or w/e mounth the front of the leafs to that.. then mount shackles to the frame .. then mount the axle hook up the brakes and hook up some HI Steer...
these were from a Blazer project with a dana 30 but im sure you could do something simlar..
Old December 9th, 2005, 12:23 AM   #5
Chop
Mischievous Badger
Chop's Avatar
nice info who has more? for more ideas
Old December 9th, 2005, 05:19 AM   #6
Thats the way to do it. If you think that setup gives you too much lift, then you can do like a toyota and run the shackle mounts through the frame, to get them higher up so you have less lift.
Get a hole saw and a piece of tube, holesall thru the frame where you want the mount(make a jig to get it lined up and square) then weld in the tube into the frame to use as upper shackle mount.
Old December 9th, 2005, 08:17 AM   #7
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Does this mean I'm supposed to start making room in the barn?
blizazer is offline   Reply With Quote
Old December 9th, 2005, 06:03 PM   #8
GMCsonoma94
1 wheel peel
we gota finnish yours first.
Old December 12th, 2005, 07:32 AM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Have you tried the message boards on ColoradoK5.com ?
Old December 21st, 2005, 12:26 AM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Got it done yet ?
Page generated in 0.25452 seconds with 53 queries
