little motor work done - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old February 20th, 2011, 03:44 PM   #1
1TFROT
1TFROT's Avatar
Default little motor work done
quick snapshot: '00 s10/zr2 with a 6.0 LQ4. wanted more power than it was in stock form so I added some headers (with flowmaster super 44s) and had a new cam installed with some tuning. just got it back yesteday so I have not driven it yet, but it seems to be promising
sounds fairly nasty (in a good way :D ), but is a cold-blooded animal now. it took a good 5-10 mins for warm up just so it would rev above 2grand. can't wait to drive it and see how it runs! they had the dyno loaded up pretty good and said it pulled hard up to 6200rpm
cam specs should be as follows...
230/224
LSA 112+2
.591/.581
it is a custom grind that's considered a reverse split cam
1TFROT is offline   Reply With Quote
Old February 20th, 2011, 04:45 PM   #2
95geo
newbie
95geo's Avatar
Very nice!
Any reasoning behind the reverse split? They arent very common in these engines, I'm wondering what factors contributed to that decision.
What RPM is your idle at?
Old February 20th, 2011, 04:58 PM   #3
1TFROT
1TFROT's Avatar
thanks! they recommended the reverse split due it was suppose to create more power on the low end, a little quicker. he did say it was a little older technology, but they work very well for low end torque applications. a little above my paygrade, but something about quicker ramp-up vs other stuff
idle is about 700-800 from what I remember on the tach.
Old February 20th, 2011, 04:58 PM   #4
6.0's are over rated.
Sounds good.
Old February 21st, 2011, 05:45 AM   #5
1TFROT
1TFROT's Avatar
Sounds good.
thanks
Old February 24th, 2011, 07:34 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
what kind of headers did you do with ? and who did your tune ?
Old February 24th, 2011, 11:05 PM   #7
1TFROT
1TFROT's Avatar
pretty sure the headers are headman (bought through Summit) and the tuning and cam was done by Straightline Performance (1320hp.com)
Old February 24th, 2011, 11:10 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
sounds great!
H.o.r.e
Old February 26th, 2011, 06:37 PM   #9
c0ncEpT
c0ncEpT's Avatar
Send a message via AIM to c0ncEpT
Sounds good but who did you say tuned it?
Is it still FI or did you put a carb on it?
No LS motor should have to warm up for 10 minutes before it will rev above 2K.
c0ncEpT is offline   Reply With Quote
Old February 26th, 2011, 07:27 PM   #10
1TFROT
1TFROT's Avatar
it's FI. pretty sure they explained as a safety thing for the tuning. more rpm's are allowed as the coolant temp rises towards full operating temps.
Old February 26th, 2011, 07:39 PM   #11
c0ncEpT
c0ncEpT's Avatar
Ah well that makes a lot of sense then.
You'll be happy with it I'm sure. With the advance they ground into the cam its going to make the power come on sooner as it helps raise the Dynamic compression.
We used a 230/230 in my buddys LS1 goat and cam only it made 400 to the wheels and had plenty of power in the lower RPM's.
Reverse splits do work in LS motors.
Old February 26th, 2011, 08:09 PM   #12
1TFROT
1TFROT's Avatar
good to know, thanks. might actually get to drive it in the next day or 2
Old February 26th, 2011, 08:16 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
Dammit i forgot you're in Chicago. Ive been looking for a place that does a lot with Gm truck engine tuning.. Livernois has an awesome rep here locally with LS series engines so i'll probably end getting with them
Old February 26th, 2011, 08:51 PM   #14
c0ncEpT
c0ncEpT's Avatar
http://www.stenodperformance.com/
http://www.engineeredvictories.com/
http://www.bakerengineeringinc.com/
Old February 26th, 2011, 09:15 PM   #15
schanxj
schanxj's Avatar
Sounds pretty mean! Love the SX2's as well.
schanxj is offline   Reply With Quote
Old February 26th, 2011, 11:02 PM   #16
1TFROT
1TFROT's Avatar
thanks
Page generated in 0.42051 seconds with 71 queries
