My 151 proof buggy - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2011, 04:39 AM   #301
jhnyquest
goof ball
jhnyquest's Avatar
Flowmaster
Old August 3rd, 2011, 04:06 PM   #302
Grassman
2jz specialist
Grassman's Avatar
i think you will be better sending it out to get coated with your headers and such. my guess is that the way they are stamped and assembled it will be a pita to do.
Old August 3rd, 2011, 05:08 PM   #303
jhnyquest
goof ball
jhnyquest's Avatar
The entire exhaust will be coated. I am sure modifying it will suck but I am concerned about heat on pass floor. After driving and riding in Gradys car the floor temps were huge from side to side.
Old August 3rd, 2011, 05:34 PM   #304
Grassman
2jz specialist
Grassman's Avatar
i see...how much clearance are you looking for?
Old August 3rd, 2011, 06:23 PM   #305
jhnyquest
goof ball
jhnyquest's Avatar
I am looking for every bit I can get.
Old August 3rd, 2011, 06:26 PM   #306
Grassman
2jz specialist
Grassman's Avatar
relocation is out of the question i assume...
Old August 3rd, 2011, 06:38 PM   #307
jhnyquest
goof ball
jhnyquest's Avatar
No not necessarially. However to relocate modifications are a must.
Old August 3rd, 2011, 06:40 PM   #308
Grassman
2jz specialist
Grassman's Avatar
i think that is a better idea before cutting up a new flowmaster, you are gonna open up a can of worms either way. if you cut the muffler im sure you will change the sound and performance too
Old August 3rd, 2011, 06:59 PM   #309
jhnyquest
goof ball
jhnyquest's Avatar
Perhaps you should stop by for a better look and I think everything will make more sense.
Old August 3rd, 2011, 07:09 PM   #310
Meijer cherry bomb FTW!!!
Old August 3rd, 2011, 07:12 PM   #311
jhnyquest
goof ball
jhnyquest's Avatar
That would be awesome.
Old August 3rd, 2011, 09:11 PM   #312
Grassman
2jz specialist
Grassman's Avatar
i will be in GH all weekend, im sure i can make time since i will only be a few mins away. you gonna me in the man cave sat and sunday?
Old August 4th, 2011, 04:37 AM   #313
jhnyquest
goof ball
jhnyquest's Avatar
I am planning on spending most of my weekend out there.
Old August 4th, 2011, 12:26 PM   #314
Maybe just lizard skin the bottom of your flooring instead and jam a heat shield in there. Airbake pans work really well from what I've read
Old August 4th, 2011, 12:46 PM   #315
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
You will want the exhaust away from the floor as you know. I had my exhaust 1" away from the floor in my jeep thinking it was enough. I burned the heel off my Rocky boot
Old August 4th, 2011, 01:06 PM   #316
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
I did a few muffler cuts/designs/builds back in the late 80's for bowtie small and big block motors when I worked for a couple racers at the oval track. There are some neet little tricks to checking flow through the muffler. Sound is a crap shoot though if you make any major modifications.
Old August 4th, 2011, 01:24 PM   #317
Look into some stuff called "glasstherm" JQ. We used to use it to isolate the copper electrodes on automated weld cells from the steel plates they were attached too. It doesn't transfer heat very well. 1/8" used to keep the steel plates from heating up at all.
Old August 4th, 2011, 07:45 PM   #318
jhnyquest
goof ball
jhnyquest's Avatar
Well I had a free few minutes tonight so I tore the exhaust apart and modified the muffler. I took a fair amount off the discharge side and only a little off the inlet half of the muffler.
Rough numbers show a 1/2" gain in pass floor clearance.
Old August 6th, 2011, 08:23 AM   #319
jhnyquest
goof ball
jhnyquest's Avatar
Muffler is back together. Thanks for the trick FF things looked great when I did that.
Old August 6th, 2011, 08:51 AM   #320
creeping death
I'm that guy.
creeping death's Avatar
very cool!
Tags
sexy as hell!!!
Page generated in 0.31691 seconds with 84 queries
