Dana 30 Posi Lock System - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2011, 09:09 AM   #1
jordanpetruska
jordanpetruska's Avatar
Default Dana 30 Posi Lock System
I've got a 90 YJ and my vacuum actuator isnt working at all. followed all my lines, cant find any breaks or leaks, yet i have no vacuum to the axel. I've been looking into the Posi - lok systems that run off a pull cable. Can anyone give me any advice on where to get one? how much im going to spend? and if they work?
I've read on a couple forums about guys making these systems for around
$30. And i look online and find the complete system for upwards of $200. The snow is melting, the trails are getting muddy and i wanna go play!
If anyone has any ideas or suggestions please let me know.
thanks.
jordanpetruska is offline   Reply With Quote
Old February 19th, 2011, 02:41 PM   #2
yyj87
yyj87's Avatar
thanks.
If your not locked in the front just run a stack of washers! Sure you will spin the front driveshaft all the time but tjs did from the factory.
IMHO the vacume disco would be worth fixing, theres a cheep switch that threads into the TC near the spedo cable. That could be your issue!
Shawn
yyj87 is offline   Reply With Quote
Old February 19th, 2011, 10:58 PM   #3
bdd1469
bdd
bdd1469's Avatar
Im pretty sure the hot ticket is to put a tj or xj non disco.right axle shaft in your yj and just cap the actuater mount. Im sure ill be corrected if im wrong.or put a new vacum switch in the top of your t-case and make vacum again.
Old February 19th, 2011, 11:09 PM   #4
MiNi Beast
MiNi Beast's Avatar
D30 homebrew posi lok
Old February 19th, 2011, 11:19 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
if this will work (i dont know anything about it) i may have an extra tj shaft laying around, i dont remember if i sold my extra shafts or not. i will give you a call if i got one. i will be home from cali monday night. you need to bring the new ride over and break it in one of these days!
Old February 19th, 2011, 11:22 PM   #6
MiNi Beast
MiNi Beast's Avatar
How-To: TJ Axle Shaft Conversion
Old February 19th, 2011, 11:39 PM   #7
chadcooper55
Originally Posted by MiNi Beast View Post
thanks for the tech find mb ill let you know jordan.
Old February 20th, 2011, 12:01 AM   #8
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
did it ... didn't work as well as it was made out to work. maybe I screwed something up?
did it 2 weeks ago. works fine. that particular tech article isn't bad but seemed to go about things the hard way?
pm me if you need some advice.
Old February 20th, 2011, 12:06 AM   #9
HVYRTFT
Reed my teef
HVYRTFT's Avatar
x2. I've done this several times.
Old February 20th, 2011, 12:08 AM   #10
yyj87
yyj87's Avatar
This guy wants to go wheeling now!
Pull that actuator out and use a peice of garden hose/ fuel line to hold it in the locked position so that you can wheel untill get your mind made up and parts in hand.
Or go to the auto parts and buy a new vacume switch and spend 7 minuites installing it so that the system works as intended. I have used bothe the home made and the 200 dollar cable lockers and there a bitch to operate. Buy the damn switch.
Shawn
Old February 25th, 2011, 01:00 PM   #11
jordanpetruska
oh it'll be out on your little playground as soon as the 4x4 is working.
Old February 25th, 2011, 01:02 PM   #12
jordanpetruska
tj shaft looks like the winner. have to see what i can do about finding one now.
Old February 27th, 2011, 08:41 AM   #13
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I have 4
Tags
posi lok posi lock
Page generated in 0.48549 seconds with 62 queries
