I guess he thought we couldn't fix it... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2005, 07:35 PM   #1
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Default I guess he thought we couldn't fix it...
KILLER"B"3 vbmenu_register("postmenu_4831344", true);
Registered User
Member #54970 Join Date: Oct 2005
93 K-5 rear brakes
I did a search and it had some decent info altough, the last post was in 01. So I hope I can get a little more on the rear brakes other then they SUCK!!!. Thanks
93 K-5 Blazer, new brakes all around with ABS front. I put new rotors and drums on instead of turning them. The pedal is normal and the fronts work very well. I have great brakes going in reverse, but very little rear brakes when applied going forward. I hear this is a common problem, but it is my wifes rig and my 2 boy's ride in it daily. I have tried different brake brands, and as of now I have wagner "quiets" on there now. It has a new MC and has been pressure bleed.
I have to say we can fix it or at least heckle your lack of progress as good as anyone at Pirate
Yetti
Old December 9th, 2005, 07:35 PM   #2
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
did you do the special bleed procedure for the ABS? doubt that would make it stop in reverse but not forward, that kinda sounds like you got somethin backwards in there.
GMCsonoma94 is offline   Reply With Quote
Old December 10th, 2005, 08:27 AM   #3
Yetti
Yetti's Avatar
we talked a bit last night in chat, I think he said it started after a "Panic stop", so there has to damage somewhere. I beleive he will find a bad flex hose. given the work I do I have to build custom brake systems and I blow them on ocasion.
Yetti
Old December 10th, 2005, 10:02 AM   #4
shawn
Resident HVAC/R Jambi
shawn's Avatar
Does it have ABS? If so, I had the ABS module go bad (under the hood by the MC), and I had breaks, but they were real soft, I could stop but not very good. And it happened after a panic stop.
Old December 10th, 2005, 10:20 AM   #5
rm25x
rm25x's Avatar
ABS sucks.... nuff said. Glad none of my vehicles have it.
rm25x is offline   Reply With Quote
Old December 10th, 2005, 05:37 PM   #6
Yetti
Yetti's Avatar
theres nothing in a kelsey hays module that could release presure without activating the module. the fact they are stopping wierd is the issue. if its normal operation they should be working fine as the normal system operates around the module till its activated
Yetti
Old December 12th, 2005, 07:16 PM   #7
shawn
shawn's Avatar
Well, my ABS broke and was leaking fluid (not externally) around something causing terrible breaking. :dunno:
Old December 12th, 2005, 08:27 PM   #8
noodles
give 'er sh*t ay?
noodles's Avatar
he has to have somethign reversed in the rear drums,or broke a return spring. abs would have nothign to do with it not stoping going forward and stoping in reverse.
Old December 15th, 2005, 01:31 PM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Yep you all are right, I have checked and done the above. Like I said before the shoes are on right, new springs, new drums, new shoes, new pads. I have yet to check the flex hose , but when talking with yetti I mentioned that was last to check. The truck needed brakes anyway. As far as the brakes, the ABS works. Didn't say anything about anybody here not being able to help. Let's see membership here 449 at pirate 57,513+ a lot more info so I thought.
Anyways, I guess I forgot to wear my "S" on my chest today. I forgot I am not "ASE" certified. Therefore I must not know what I am talking about.
Oh and Yetti why is this such a big concern to you... Since you know brakes, then you will know that the shoes are the same size... Upon further investigation I have found a sticky proportioning valve. I will try to clean it better by flushing it more rather then removing it. I guess I stuck the valve under the panic stop.
Have a good day!
Old December 15th, 2005, 04:05 PM   #10
Hmm, been thinking about this all day.
It does *seem* like its a geometry issue. Drum brakes are self energizing, and should be, in the forward direction. Sounds like they are reversed somehow and now energizing in the reverse direction.
Thinking about the lines, if there was an issue with lines, or the prop valve, I'd expect it to manifest in either forward or reverse direction, so I'm thinking something inside the drum.
Adjustments are good so the shoes are getting contact across the entire shoe face, not just at the top?
Having no experience with chevy brakes, I trust you that they are the same size. Maybe try swapping them front to back anyway, just to eliminate any other variations in pivot points or spring locations, or something wierd?
Or even go so far to swap all the right side stuff to the left and vice versa..
I searched 480 responses on pirate and a bunch on google (really slow at work today) and didn't find anything similar.
Old December 15th, 2005, 05:56 PM   #11
KILLER"B"468
Yankabilly
I have had 3 different brands on there, I doubt switching from side to side will do anything. The shoes ARE the same size it doesn't matter. ALL 4 in a box are the same. Same thickness, same length, same width.With playing with it some more I found out why they worked better in reverse. The E-brake was applied a few clicks. Now it stops the same forward or backwards.
Old December 15th, 2005, 06:50 PM   #12
Ahh... makes since..
so...do they work equally good or equally bad now? (i.e. is there still a problem, or all cool?)
Old December 15th, 2005, 08:05 PM   #13
KILLER"B"468
Yankabilly
Back to the way they were when I got the truck.
Old December 15th, 2005, 10:57 PM   #14
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
i heard you just plain dont know what you are doing when it comes to brakes.. should just leave it to the pros at midas.
Old December 15th, 2005, 11:03 PM   #15
I heard George Foreman knows his stuff..
Old December 15th, 2005, 11:16 PM   #16
KILLER"B"468
Yankabilly
Hell yeah I have an appt. with them on monday. $59.99
Old January 13th, 2006, 06:36 PM   #17
noodles
give 'er sh*t ay?
noodles's Avatar
hey give him a break, stupid crap happens to everyone.. and the simplest thing is over looked.
Page generated in 0.36377 seconds with 74 queries
