Can I get away without running an EGR valve on a TBI 350? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2011, 03:08 PM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default Can I get away without running an EGR valve on a TBI 350?
I've got an 89 TBI 350 that needs an EGR valve. Been driving it for a month or so now with the vacuum line to the valve plugged and solenoid harness unplugged and it runs great. I used to run some of my carbed engines with an EGR block off plate, so I'm wondering if I can do the same to this engine? I see on the Jegs website they even make block off plates for LS series engines as well.
Ready4Wheelin is offline   Reply With Quote
Old February 15th, 2011, 03:56 PM   #2
skiera231
yes you can run a block off plate on them. i did it to mine and did not have any problems. matter in fact it seemed to run a little better.
skiera231 is offline   Reply With Quote
Old February 15th, 2011, 04:19 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Yes. Those engines were never originally designed to run an EGR system. The EGR system was just an add-on to pass emissions. It isn't like modern engines that will not run right without them. Your engine won't know the difference.
Old February 15th, 2011, 04:21 PM   #4
greygoose
I'm the dude
greygoose's Avatar
x2!
Old February 15th, 2011, 09:02 PM   #5
Ready4Wheelin
Thanks guys, I was pretty sure I didn't need it. GreaseMonkey, I can believe that, due to the fact that there's no other emissions crap on this truck anymore. FWIW, this truck has 225,xxx on it. It popped a head gasket about 100k ago, and while I had it apart, I swapped in a bigger yet streetable cam, 3 angle valve job, new valve guides/seals/springs, port/polish heads & intake, and topped it off with the larger Edelbrock TBI unit. Truck runs great for the miles, pretty fun for an old 3/4 ton Sierra!
Old February 15th, 2011, 09:12 PM   #6
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
x3!
Did the same thing on my old 91, kept throwing a code and I put a blocking plate on, ran great (didn't really run better, but didn't have any problems, and no negative effect to fuel economy )
Old February 15th, 2011, 09:15 PM   #7
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
We have notified Al Gore and he is on his way to pick you up right now.
dougstephvoor is offline   Reply With Quote
Page generated in 0.22522 seconds with 44 queries
