Heps me - Tie rod ends - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2011, 12:16 PM   #1
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default Heps me - Tie rod ends
Scenario:
1/2 ton GM spindles/steering arms with 7deg taper to mount tierods from the top.
What I need to do:
Mount the tie rod ends from the bottom side of the arms (i.e., I need the taper exactly opposite of what I have). I need to do this to optimize my steering geometry / negate bumpsteer.
Any suggestions?
@clarkstoncracker
Old February 14th, 2011, 12:43 PM   #2
s.hembree
s.hembree's Avatar
I have seen several of the hot rod guys that switch to a rack use small heims with tapered studs. Is that an option for your setup?
Old February 14th, 2011, 12:53 PM   #3
Complete Off Road
Complete Off Road's Avatar
if there's enough material on the knuckle, use a tapered reamer and tie rod end bushings if needed
reamer link (or find somebody on GL who has one)
http://completeoffroad.com/i-122857-...-in-u-s-a.html
tie rod bushings
http://completeoffroad.com/i-123283-...ana-44-60.html
Complete Off Road is offline   Reply With Quote
Old February 14th, 2011, 01:43 PM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sorta - except the taper goes the wrong way.
tie rod bushings
I'm wondering if there is a difference between the 1/2 ton & 1 ton TRE stud size - that would determine if I need the sleeve or not...
@clarkstoncracker
Old February 14th, 2011, 02:11 PM   #5
Complete Off Road
I took some measurements of a Chevy 1-ton TRE on the shelf.
Largest diameter of taper - .785"
Smallest diameter of taper - .710"
Threaded stud diameter - .615"
remember that I did this quickly and these should be considered approximate measurements
Old February 14th, 2011, 02:11 PM   #6
Bishop
Bishop's Avatar
I don't know about that application. But I do know that the tie rods I got from JCR for my 1-ton steering, the drag link joints are a different dia then the tie rod ends.
Old February 15th, 2011, 04:51 AM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Awesome! I'm off to get some measurements on mine with some calipers.
Thanks!
Edit:
73-87 GM 1/2T TRE:
Largest diameter of taper - 0.730"
Smallest diameter of taper - 0.600"
I'm not positive, but I thinK I might be able to get away with drilling 45/64" (0.703") & reaming for using with the 1T TREs...
@clarkstoncracker
Old February 15th, 2011, 08:20 AM   #8
Bones
Bones's Avatar
I swear I have seen exactly what you need on speedway motors. I'll look tonight. Or give them a call, they're helpfull people.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 15th, 2011, 08:22 AM   #9
Bones
Bones's Avatar
Or why not drill the whole thing out to .75" and use a .75" heim and bolt?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 15th, 2011, 10:19 AM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Something like this? I need that, but "upside down"...
That is another possibility too.
@clarkstoncracker
Old February 26th, 2011, 08:32 AM   #11
SoupCan
SoupCan's Avatar
ballistic fab makes a weld in insert,drill knuckle to 1in, insert,weld,done
SoupCan is offline   Reply With Quote
Old February 27th, 2011, 11:02 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Thanks!
I may go that route if the inserts I ordered from Seven Springs don't work. They should be here Tuesday. And I should clarify- the only reason the parts from Complete Offroad wouldn't work would be if I reamed my steering out too far.
We'll see, but I think I've got it covered.
@clarkstoncracker
Page generated in 0.27417 seconds with 59 queries
