Pinto 2.0 engine, question and parts needed. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2011, 06:47 PM   #1
gmotox
gmotox's Avatar
Default Pinto 2.0 engine, question and parts needed.
I purchased a sand rail with this Pinto 2.0 engine and would prefer a VW air cooled engine.
Looking for an intermediate shaft for Ford Pinto 2.0..it is the shaft that drives the distributor and oil pump.
Some call it "auxillary shaft" or "intermediate shaft"
Any resources or links to buy new would be great..not looking to buy a new billett one..
What kind of sale value does a Ford Pinto 2.0 engine with 4 single Mikuni carbs and header have, it is said to run great but intermediate shaft is broke ?
Thanks for any help!
Old February 13th, 2011, 06:51 PM   #2
gmotox
gmotox's Avatar
Any Ford gurus know where to get a Pinto 2.0 intermediate shaft?
Old February 15th, 2011, 01:44 PM   #3
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Still available through Ford, $79. It should be the same in the later 2.3 engines too; all the way up to '88.
Troll53 is offline   Reply With Quote
Old February 15th, 2011, 06:28 PM   #4
gmotox
gmotox's Avatar
I will try the dealer but I have found out the 2.3's are differant..
Thanks!
Old February 15th, 2011, 06:39 PM   #5
insaneoffroader
insaneoffroader's Avatar
If all else fails check with these guys;
http://www.esslingeracing.com/
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old February 15th, 2011, 06:49 PM   #6
deathbypsi
Brian R.
deathbypsi's Avatar
If the gears on the shaft broke the gears on the distributor will be trashed also not to mention tons of shavings in the oil pan.
Something to think about if its already setup for a 2.0,instead of re-doing everything for a VW motor you should look into swappin in a Turbo 2.3 out of a T-bird or Merkur.My buddy in Jackson did this swap and even with a stock 2.3t it will make 175-200hp without trying. He had to build a new buggy with a longer chassis just to keep the front wheels on the ground so he could steer. If you get a Merkur motor and harness its a super easy swap and the harness is a stand alone so its small and easy to hook up.
Old February 15th, 2011, 10:26 PM   #7
gmotox
gmotox's Avatar
Thank you, but already called them and they have no 2.0 stuff
The distributor gear is good..I thought about the 2.3 swap but would really rather have the VW aircooled to keep it simple and light, the light front end was a probleem with this buggy also..I have another nice 4 seater frame that I am swapping everything into.
Thanks for the info!
Old February 16th, 2011, 05:45 AM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
RacerWalsh is another big 2.0/2.3 vendor as well. They deal mostly with the roundy-round guys who love the 2.0
I am into 2.3 Ford stuff big time and have delt with Esslinger and Walsh many times.Prices are a bit high but remember you aint dealing with SBC parts so it comes with the teritory.
Old February 16th, 2011, 09:10 AM   #9
gmotox
gmotox's Avatar
Thanks but not available through Esslinger or Walsh...It looks like I need to find someone who has one laying around..
Old February 27th, 2011, 09:53 PM   #10
gmotox
gmotox's Avatar
still looking!
Old February 28th, 2011, 02:46 AM   #11
deathbypsi
Brian R.
deathbypsi's Avatar
www.turboford.org
Page generated in 0.33073 seconds with 56 queries
