Front end griding noise 94 F150 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2011, 08:25 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default Front end griding noise 94 F150 4x4
So I went and looked at a decent 94 F150 4x4 yesterday for $1,000 bucks, and everything was good until I took it for a test drive. Every time I would turn the wheel you'd hear a cracking / grinding sound coming from the front end, especially if I put it in 4x4. I could see anything wrong when I looked around the front end. Nothing was rubbing or anything and the springs look fine. Any ideas??? Would bad front end U joints cause this?
chevyk10 is offline   Reply With Quote
Old February 11th, 2011, 08:27 AM   #2
Bishop
Bishop's Avatar
Front axle U-joints or cv joints.
Might as well ask. was this while moving or at a stop?
Old February 11th, 2011, 08:49 AM   #3
chevyk10
FORD / GM
chevyk10's Avatar
At a stop. The guy claims he doesn't know anything about this truck which kinda makes me nervous. He said all he knows is that a guy brought this truck to a shop to get repaired, they fixed it, and then he never paid so they took the truck, then sold it to this guy that is selling it now. Only other issue it might have is the clutch doesn't seem to engage until the pedal is almost all way up and doesn't seem stiff at all. I'm not sure if that's a good thing or not.
Old February 11th, 2011, 09:04 AM   #4
Bishop
Bishop's Avatar
In that case you should prolly have a friend help and turn the wheel while you are checking things out. If it's that loud you shouldn't have a hard time pinpointing the noise.
I would be looking at all the steering components, and not as likely now that it does it at a stop but also the axle U-joints.
Old February 11th, 2011, 09:32 AM   #5
Quiefinator
go'til itsounds expensive
The grinding would make me think hub or brakes. But if it is happening @ a stop you could probably rule out the brakes. If you have a floor jack, check ball joints and while the tire is in the air you might be able to move it around and find the play.
Old March 25th, 2011, 05:02 PM   #6
freighthammer5
freighthammer5's Avatar
Had that happen to my Exploder , a u-joint seized up causing the hub to grenade, horrible grinding noise, with a slight clunk.
freighthammer5 is offline   Reply With Quote
Page generated in 0.31122 seconds with 41 queries
