ZJ Steel Bumper. ***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2011, 12:09 PM   #1
Grifter
Human Hunter
Grifter's Avatar
Default ZJ Steel Bumper. ***SOLD***
Hey all the Jeep is gone, Before we donated it I pulled the homebuilt Steel bumper off it. Bumper was built by a friend a couple years back. And has taken a decent amount of abuse.
Was mounted to a 97 ZJ with a 96 ZJ front clip. Will fit early zjs best, but with some welding you could fiill the voids under the head lights to fit a 97-98.
It needs a good sand blasting and some tender love and paint care.
It is very heavy.
It mounts up using a Tie in bracket like a XJ that slips inside the unibody frame rail.
You will need to source H2/3 Shackles to make the tow points work. The holes are too close to the body of the bumper to accomodate standard clevis shackles.
Oh yea. located in Downtown Rochester. NE Oakland County. I can and will meet within reason to deliver it for a reasonable offer.
$175 now $110
Dimensions...Bumper is
65.5 inches wide.
17in. from front face to the back of each side piece.
6in tall in the center
4 inches tall at the outer edges and then tapering towards the back.
Each mounting bracket (which are thru welded and include the d ring tabs. are 1/2 inch thick and 8 inches long(measured from the back of the bumper back.).
The brackets measure 32.5 inches apart (outside facing edge to outside facing edge) and each is inset from the side 16 in.
Each bracket is also 3.25 in tall.
Grifter is offline
Old February 10th, 2011, 02:57 PM   #2
newdodge
jeep life
newdodge's Avatar
trades ?
newdodge is offline
Old February 10th, 2011, 06:31 PM   #3
Grifter
Human Hunter
Grifter's Avatar
Trades, Maybe. Depends on what you got. Really in the process of off-loading a bunch of junk, I dont really need more.
Things I need or am looking for.
Xj 4.5in coils, 8.8 w/ 4.10's, D30 lower control arm brackets and other upgrade stuff, 8.8 xj leaf spring perches, 4.7 liter stroker stuff, Most any jeep upgrades. In need of a 97+ xj AC compressor clutch kit. Edit to add. Front skid for XJ or for that matter any skid for an xj.
Otherwise. Firearms/stuff (think tactical), Kayaks, Camping.
Grifter is offline
Old February 11th, 2011, 04:49 PM   #4
Grifter
Human Hunter
Grifter's Avatar
$150 obo..
Grifter is offline
Old February 13th, 2011, 09:53 PM   #5
Grifter
Human Hunter
Grifter's Avatar
Late night Bump..just for the heck of it
Grifter is offline
Old February 14th, 2011, 04:20 PM   #6
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
My cousin needs a bumper like this. I just told him. I will let you know.
tcxtreme1000 is offline
Old February 14th, 2011, 04:29 PM   #7
greenzj
Cleanest 5.9L ZJ around
greenzj's Avatar
Just a heads up. It was mounted to a 93-95 front end. not a 96. a 96 is the same as a 97 or 98. Bump for a good price
greenzj is offline
Old February 14th, 2011, 04:51 PM   #8
Grifter
Human Hunter
Grifter's Avatar
Ok sorry for that, after the head on collision that was the catalyst for getting the bumper made. I bought a bunch of front end/clip stuff from a guy that told me it was coming off a 96. Hence the misprint thanks for the clarity and for the bump. Cheers..
Oh and for clarities sake I just bought a used jcr class 3 xj front and this bumper is only a wee bit heavier then the JCR one. So its not a heavy as I originally thought. I will try to get an actual weight tomorrow.
Grifter is offline
Old February 18th, 2011, 05:35 PM   #9
Grifter
Human Hunter
Grifter's Avatar
Sorry failed on the weight, thought we had a functional scale at work. But it seems our mechanic broke it at some point.
Up for the evening..
Make an offer..
Grifter is offline
Old February 19th, 2011, 01:42 PM   #10
emev0l
emev0l's Avatar
Will this bolt directly onto a 97 Grand?
emev0l is offline
Old February 28th, 2011, 03:47 PM   #11
Grifter
Human Hunter
Grifter's Avatar
Sorry I missed the last post somehow.
The bumper was bolted directly too a 97 ZJ using holes in the frame rail. However, the front clip was changed to a 95 set up due to an accident. I can for certain tell you the mounting at the frame will be the same. There might be some alignment issues with the lower lip of the 97 grill.
Otherwise bump...
Grifter is offline
Old March 15th, 2011, 05:19 PM   #12
Grifter
Human Hunter
Grifter's Avatar
$135
Grifter is offline
Old April 6th, 2011, 03:39 PM   #13
Grifter
Human Hunter
Grifter's Avatar
$110
Grifter is offline
Old April 8th, 2011, 05:44 PM   #14
Grifter
Human Hunter
Grifter's Avatar
added Dimensions to the original post for those of you thinking about modifying it to fit some other rig.
Grifter is offline
Old April 8th, 2011, 06:16 PM   #15
llib
THE TAIL LIGHT KILLER
llib's Avatar
i still want it call me248-379-7414
llib is offline
Old April 8th, 2011, 08:35 PM   #16
HeavyArms
Hit the lights
HeavyArms's Avatar
To bad ur so far away or id take it. if llib dosnt take it mabe we can work sumthing out.
Bump for a hell of a deal on a sweet zj bumper!
HeavyArms is offline
Old April 8th, 2011, 08:55 PM   #17
newdodge
jeep life
newdodge's Avatar
i will take it if he doesn't pm number
newdodge is offline
Old April 14th, 2011, 07:00 PM   #18
Grifter
Human Hunter
Grifter's Avatar
sale pending.....
Grifter is offline
Old April 16th, 2011, 01:24 PM   #19
Grifter
Human Hunter
Grifter's Avatar
Sold
Grifter is offline
Page generated in 0.39439 seconds with 80 queries
