97 f350 7.3 water pump - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2011, 07:20 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default 97 f350 7.3 water pump
I have a squeal and spots of coolant on the ground. Sooo looks like its time to do a water pump.
I've been doing some research and it seems people like to use the Airtex pumps that can be had for under $100 shipped instead of the Motorcraft which is $300+
another choice is the NAPA brand at $140 something?
anyone have any experience with either of these?? Do not want to have to do this again.
Old February 8th, 2011, 08:06 PM   #2
7.3X
Fullsize support vehicle
7.3X's Avatar
The NAPA brand is good. I personally do not like the Airtex pumps.
7.3X is offline   Reply With Quote
Old February 9th, 2011, 09:22 AM   #3
kickstand
circling the drain
kickstand's Avatar
I look at it like this.
The oem part lasted how many miles? Is $300+ worth it to not have to fix it for that many more miles? OR is the $200 savings worth the gamble?
I know the cost is hugely different, and the process is also probably different, but I did a waterpump on my friends 4.3 liter sonoma. it took an hour and a few minutes, was fairly simple, she bought the cheapest waterpump she could find, in her case I'd do the same everytime as it was a quick easy job.
On the otherhand, if it had taken me 6 hours to do, I would have probably bought an OEM part in hopes it would last as long as the first.
Old February 9th, 2011, 04:46 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I bought the Napa brand. Its brand new and i did some reviews and seems like a lot of 7.3 guys use it. Its lifetime warranty so if it does go bad I get a new one..... I'm not sure how old the pump that is on it is. The truck has 245k miles on it so I'm sure its not OEM.
Old February 9th, 2011, 05:52 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
this job takes like 30 mins. srsly. super easy
Old February 9th, 2011, 06:48 PM   #6
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I replaced mine with the lifetime Napa pump and it looks like it is better than the OEM in my opinion. All 1 peace casting as opposed to the pump with plastic water inlet bolted on on the one I took off. Replaced it 2 years ago and no issues.
GNJEEPN is offline   Reply With Quote
Old February 10th, 2011, 09:35 AM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I do like the one piece. Just hope the pump is where it leaks. Can't see the weep hole. Send it started leaking when the chirping sound started
Old February 10th, 2011, 10:45 AM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
get yourself the hottest T-stat, if you haven't already.
@clarkstoncracker
Old February 10th, 2011, 06:37 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I went with the Napa stat a few months ago and it Works great. I also used cardboard to block the radiator. It stays nice and warm while driving on the freeway.
I have a TS 6 position chip and it has the Hi-idle. That combined with my "jake brake" switch, thing will throw heat in 5 mins.
Page generated in 1.16300 seconds with 50 queries
