Good deal on Tube Bender? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 5th, 2011, 12:21 PM   #1
93gmcZ71
93gmcZ71's Avatar
Default Good deal on Tube Bender?
Just happend to find this bender and was wondering if any one has heard about or used it? It looks like a decent deal and from there ebay add they are located in SW Michigan.
http://www.careybender.com/main.html
93gmcZ71 is offline   Reply With Quote
Old February 5th, 2011, 12:34 PM   #2
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
I have one,...............
It does Okay bends, Its a little time consuming on setups for each bend as well. I go through a lot of hoop bolts.
I have an air/hydraulic cylinder attached to mine as well.
Old February 5th, 2011, 02:12 PM   #3
jhnyquest
goof ball
jhnyquest's Avatar
I you ever plan on bending a lot of tube those suck. They are slow. I had one and got rid of it. If I remember correctly it was only able to bend to 90 degrees so you have to 2 piece your shock hoops.
Old February 5th, 2011, 02:35 PM   #4
FORD FLARESIDE
X2
I have the one you got rid of
Old February 10th, 2011, 07:24 AM   #5
evlxb
I bought the Gottrikes plans and built my own. I think there is $225 in materials and $250 into a 180 deg 1.75 die set. Works awesome.
evlxb is offline   Reply With Quote
Old February 11th, 2011, 12:12 AM   #6
sodapop
Support the Sport!
sodapop's Avatar
You can buy an "Affordable Bender" cheaper off ebay and it's basically the same thing.
http://cgi.ebay.com/ebaymotors/Affor...motiveQ5fTools
I was going to buy one but the big downside is that the bend is based on a 7" diameter which isn't very tight and you can't make it tighter with a different die either.
The Eastwood one is similar too and it about the same but comes with more dies.
http://cgi.ebay.com/New-Hydraulic-Me...item56426a5616
Page generated in 0.24669 seconds with 41 queries
