c-clip removal with locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2011, 12:39 AM   #1
rangerluc
rangerluc's Avatar
Default c-clip removal with locker
any tips or tricks that you guys know of to remove the c-clips out of a locker? ive got the 8.8 and i need to replace a seal, but iirc those c-clips are buried inside of the locker. i have a lock right. just contemplating on how i am going to get those little buggers out so i can pull the shaft
rangerluc is offline   Reply With Quote
Old February 3rd, 2011, 07:58 AM   #2
Dylan
Dylan's Avatar
there should be plenty of room to get it out with a magnet through the cross shaft hole. That's how I have always done it on a D35. Don't know if the 8.8 is the same or not.
Old February 3rd, 2011, 08:03 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
I'm not familiar with the lockright, but with my aussie, i have to remove the springs and pins first.
Old February 3rd, 2011, 12:51 PM   #4
littletrucker
I'd hit that
littletrucker's Avatar
Haven't messed with an 8.8 but in my d35 with an Aussie just pulling the center pin and setting the teeth up on each other on the side you want to take out gets you plenty of room- push the axle in to line the c clip up with the slot and they should pop right out basically.. maybe a little persuading with a pick, or turning the carrier so the slots point straight down and more wiggling and the clip should fall down.
Old February 3rd, 2011, 03:14 PM   #5
rangerluc
rangerluc's Avatar
thanks for the responses guys
Page generated in 0.13211 seconds with 38 queries
