Alright, diesel dudes got a question for ya - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2011, 08:25 PM   #1
stinkpickle
bitter clinger
stinkpickle's Avatar
Default Alright, diesel dudes got a question for ya
I bought a 1997 f250 diesel with 138,000 miles on it today. drove clear across MI to get it. My dad drove it on the way back while I followed. Every thing was fine till about 3 hours into our trip back it start making a hissing noise intermittently while cruising. It runs fine and acts normal except for the occasional hiss during cruising speed and when he put the pedal down it doesn't seems to have the spunk it had. What could it be ?
stinkpickle is offline   Reply With Quote
Old February 2nd, 2011, 08:31 PM   #2
mprmn08
mprmn08's Avatar
boost leak. does it only hiss when it starts to get a load on it?
Old February 2nd, 2011, 08:31 PM   #3
mprmn08
mprmn08's Avatar
and is it intercooled or not?
Old February 2nd, 2011, 08:37 PM   #4
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
97 is not intercooled stock.
Old February 2nd, 2011, 08:40 PM   #5
stinkpickle
bitter clinger
Going by what my dad said, he said it did it when cruising. I took it to mean coasting down the road not on the throttle. He said it felt and heard no difference in performance other than the hiss and lack of balls when pushed hard.
Old February 2nd, 2011, 08:44 PM   #6
blade262us
blade262us's Avatar
Default Diesel
It could be the exhaust backpressure valve when it goes through a warm up cycle you will hear the hissing noise . I have an 02 and thats what it does granted 3 hrs into your trip it should have been good and warmed up but not saying a temp sensor may be going bad causing to to cycle once in awhile I have had mine cycle after it had been run for awhile and your right it has no balls because the exhaust is essentially blocked off . Something to look at .
blade262us is offline   Reply With Quote
Old February 2nd, 2011, 08:47 PM   #7
stinkpickle
bitter clinger
interesting, Ill look into it. Was this an occasional thing?
Old February 2nd, 2011, 08:50 PM   #8
mprmn08
mprmn08's Avatar
i thought late 97's had an intercooler? or is that 98.
is there any smoke when you lay into it?
Old February 2nd, 2011, 08:55 PM   #9
stinkpickle
bitter clinger
not sure, it was dark. i didn't smell any thing and I trailed directly behind the whole way.
Old February 2nd, 2011, 11:24 PM   #10
Toivo
Feel lucky?
Toivo's Avatar
sounds like exhaust backpressure valve (EBPV). mine did fucked up things like that too sometimes when I'm not using lots of boost. a couple things can cause the issue.
1. corroded/carbon plugged line (from the exhaust manifold to the EBPV sensor on front of engine somwhere) clean it out/replace the tube and/or sensor.
2. EBPV valve is sticking internally and needs to be fixed (remove turbo) or the oil seals in it are bad/weak.
that being said I don't know a ton about OBS powerstrokes, mine is a 00 and I have had this issue.
a boost leak would cause running issues and smoke.
look over on powerstroke.org, great site to browse and get info.
Old February 3rd, 2011, 04:23 AM   #11
stinkpickle
bitter clinger
thanks guys, you've been helpful. Ill dig into this thing and let you know what I come up with.
Old February 3rd, 2011, 09:09 AM   #12
Bones
Bones's Avatar
as mentioned, it's the EBPV.
no intercooler until the superduty (1999)
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 3rd, 2011, 03:44 PM   #13
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
There seems to be quite a bit of people reporting that the EBPV will stick at times or not fully open. I installed a simple On/Off switch so I ave full control if its shut or closed. This also allows you to use it as a "jake brake".
Old February 3rd, 2011, 03:54 PM   #14
mudmafia
Dr. X equals winnar
mudmafia's Avatar
Change the spark plugs?
mudmafia is offline   Reply With Quote
Old February 3rd, 2011, 07:00 PM   #15
stinkpickle
bitter clinger
Har, Har .
Old February 3rd, 2011, 07:01 PM   #16
stinkpickle
bitter clinger
If I drive with a screwed up EPBV for a few days will it screw any thing else up?
Old February 3rd, 2011, 07:26 PM   #17
blade262us
blade262us's Avatar
Default Diesel
Your mileage
Old February 3rd, 2011, 07:40 PM   #18
94transam25th
94transam25th's Avatar
x17 on EBPV
unplug it you will be much happier
94transam25th is offline   Reply With Quote
Old February 3rd, 2011, 08:17 PM   #19
stinkpickle
bitter clinger
Originally Posted by 94transam25th View Post
x17 on EBPV
Ill unplug it for now. Where is it? Is this something that can be replaced for cheap?
Old February 3rd, 2011, 08:18 PM   #20
stinkpickle
bitter clinger
Your mileage
And here I thought I was doing alright on my mileage!
Page generated in 0.37703 seconds with 83 queries
