2001 1500 RAM strange issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2011, 05:44 PM   #1
mexdsk
goofy
mexdsk's Avatar
Default 2001 1500 RAM strange issue
When driveing after it as warmed up at around 45 mph when in 4th gear I get a bucking, like either engine is shutting down and restarting or or trans is disengaging and re-engaging.
Does not do it when engine is cold, only after it has been running for 30 min or more. Above or below 45mph seem to be fine.
mexdsk is offline   Reply With Quote
Old February 2nd, 2011, 08:30 PM   #2
mprmn08
mprmn08's Avatar
check fluid level. sounds like your tc is locking and unlocking. could be your tc lock up switch.
Old February 10th, 2011, 12:20 PM   #3
mexdsk
goofy
mexdsk's Avatar
I checked fluid it is fine
I have been trying to figure out how to describe problem better (so when I do take it to a shop they will understand)
I am thinking it is related to kick down .. is that something I may be able to repair in the driveway???
Old February 10th, 2011, 01:40 PM   #4
mprmn08
mprmn08's Avatar
still sounds like tc locking and unlocking to me.
Old February 10th, 2011, 05:01 PM   #5
mexdsk
goofy
mexdsk's Avatar
I can believe TC locking unlocking .. so how do I fix that?
Old February 10th, 2011, 05:21 PM   #6
mprmn08
mprmn08's Avatar
it could be just your lock up switch if your lucky. i cant really believe its your convertor itself being bad. the module should be on the bell houseing i believe, if i remember right.
Old March 25th, 2011, 12:52 AM   #7
warner
oops, shit happens.....
warner's Avatar
i have the same problem in my 96 1500 360 4x4 but mine also randomly dies sitting still in park or neutral and sitting still in gear the torque converter just randomly locks up but only on occasion and the research that ive done is spark plug wire routing and torque converter lock up switch
warner is offline   Reply With Quote
Old March 28th, 2011, 07:20 AM   #8
mexdsk
goofy
mexdsk's Avatar
Feeling kind of stupid now about this issue .. Finally got around to this issue again
Pulled the spark plugs, they were completely wore out ..
Replaced the Plugs wires cap and rotor runs like a champ again.
Page generated in 0.29825 seconds with 47 queries
