help with vac disc on XJ axle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2011, 10:19 PM   #1
knixon804
THE GENERAL
knixon804's Avatar
Default help with vac disc on XJ axle swap
hey i have a 91 xj that has an axle that does not have a vac disc but the inner C is bent so to replace it i bought a set of axles and going to swap them in this weekend. my new axle is a vac disc style and i know i can delete that but the two piece axle shaft is weaker. my question is can i just throw the one piece axle shaft out of my other axle into this one and run it? or is there something i need to do more to make it stronger??
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old January 31st, 2011, 10:28 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
put in one piece shaft. I think you have to do something with the inner axle seal, if I remember right.
Old February 1st, 2011, 06:18 AM   #3
knixon804
THE GENERAL
knixon804's Avatar
thanks but does anyone have anymore info?
Old February 1st, 2011, 06:25 AM   #4
Tim
I UNDERSTAND!!!
Tim's Avatar
Yes, I did the same thing on my YJ. You will need to put in a inner axle seal and make a cover for the vacuum motor housing. Thats it.
Tim is offline   Reply With Quote
Old February 1st, 2011, 11:05 AM   #5
knixon804
THE GENERAL
knixon804's Avatar
what year inner axle seal?
Old February 1st, 2011, 12:03 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Read much? Check the 5th thread down in this section it is a sticky
Old February 1st, 2011, 05:31 PM   #7
knixon804
THE GENERAL
knixon804's Avatar
damn thanks man, im a dummy
Page generated in 0.16066 seconds with 44 queries
