Late 80s vs mid 90s 351 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2011, 08:41 PM   #1
dumperdave
dumperdave's Avatar
Default Late 80s vs mid 90s 351
Anyone know the difference in power between the 2? I have both but it would be easier to run the 88 motor I have. The trans is already on it and I wont have to mess with the oil filter deal and it has a good pan. I need to change the pan on the 90s engine.
dumperdave is offline   Reply With Quote
Old January 31st, 2011, 08:42 PM   #2
The later 351's had roller lifters.
Old February 1st, 2011, 07:36 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
my 93 did not have a roller cam, just FYI
Old February 1st, 2011, 07:59 AM   #4
I think 95-96?
Old February 1st, 2011, 02:44 PM   #5
dumperdave
dumperdave's Avatar
My 90s motor is a 94. Didnt know how much difference the obd1 or obd2 makes either.
Old February 1st, 2011, 02:46 PM   #6
My 96 is obd-1
don't know how accurate but
Ford_Windsor_engine Ford_Windsor_engine
Old February 4th, 2011, 10:20 PM   #7
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
i have a 96 obd2, it has mass air flow its suppose to be better for engine upgrades like a cam or bigger injectors. go on fullsize bronco.com they have alot of info on any ford.
ATOMIC_BADBOY is offline   Reply With Quote
Old February 4th, 2011, 10:43 PM   #8
IDIeselman
IDIeselman's Avatar
Roller 351s start with the casting # F4TE (94 and newer) Among a few others the lifter bores are taller in the F4 roller blocks. If you will be building for HP in the future use the 94+, If you are just running it with mild upgrades the 88 will be great.
Page generated in 0.21835 seconds with 48 queries
