96 orvis - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2011, 05:03 PM   #1
siczj
siczj's Avatar
Default 96 orvis
Been building this for a few years now figured i'd share. Bought more than a few parts from GL4X4 members. Thanks for the deals
Engine: 280HP/340FT-LB 1998 4.0L stroked to 4.6L, 1978 258c.i 12 weight crank, rods. SEAL POWER pistons, rings and a balanced rotating assembly.
Camshaft: COMP cam X4250H-13, comp lifters 822-12
Timing chain: Coyle’s true double roller
Cylinder Head: 1994 H.O casting # 7120 complete 5angle valve job and bowl blend.
All work done by http://www.moderncylinderhead.com/ Mopar Springs, Seals and Retainers were used with the stock rocker arms and pushrods.
Injection: 24# ford injectors,2001 4.0L intake Port matched and 62mm throttle body made by http://www.jeepersandcreepers.com/me...a/IMG_1038.JPG
ECU: Tuned by http://www.bgchrysler.com/ A must for a stroker.
Ignition: Stock, one step colder champion plugs
Cooling: 3 core radiator, 195* stat, FLOW KOOLER water pump, Lebaron hood vents and HAYDEN remote oil cooler.
Trans: Stock 42re with cooler.
Transfer case: NP249 swap to a NV242.
Axles: 3.73’s HP30 front and a 44HD rear. (Temporarily open)
Brakes: 4 wheel disc with ABS and RUBICON S.S brake lines.
Steering: Stock with a BDS stabilizer.
Suspension: 4.5” lift with long arms and RUSTY’s adjustable track bar in the front, 4 adjustable short arms and JKS adjustable track bar in the rear, Shocks BDS all four corners and JKS bar& pin eliminators and upper eye mounts up front.
Electrical: 200amp alternator, dual batteries, 150amp isolator, 1800watt power inverter and a 120V outlet.
Sound system: Pioneer voice navigation, 7” LCD/DVD in dash(modified), Super tuner mounted on passenger side floor and Alpine’s all around.
Recovery: ARB front bumper with a WARN M8000 winch and a Kennesaw Mountain rear bumper with D-rings.
S.F.R custom mod’s: Roof rack with 4 HID 6K watt offroad lights and a storage box for all the necessary tools and stuff.
siczj is offline   Reply With Quote
Old January 31st, 2011, 07:46 PM   #2
95ZJTIM
95ZJTIM's Avatar
How do you like the 4.0 stroked out??
95ZJTIM is offline   Reply With Quote
Old January 31st, 2011, 11:49 PM   #3
siczj
siczj's Avatar
I like it, once i work out all bugs it's been a great engine it now has 30k miles on it and only had one major problem. I lost one lobe on the first COMP cam @ 15k miles my fault i had to much preload on the lifter.
Old February 1st, 2011, 02:15 PM   #4
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
need more pics!!
98ZJ318 is offline   Reply With Quote
Old February 1st, 2011, 02:44 PM   #5
siczj
siczj's Avatar
Originally Posted by 98ZJ318 View Post
need more pics!!
What do you want to see? i felt like i posted to many!!
Old February 1st, 2011, 02:48 PM   #6
80mopar
Sic Ram
80mopar's Avatar
Why don't you tell us who assembled that beast of what used to be a 4.0 Liter?
80mopar is offline   Reply With Quote
Old February 1st, 2011, 03:17 PM   #7
siczj
siczj's Avatar
You mean put the Piston's and rod's in and the springs on the valves Why that would be my little BRO(NEWB,80mopar)
Old February 1st, 2011, 03:25 PM   #8
Jeep ZJ
Jeep ZJ's Avatar
bad ass grand! i like!!
Old February 1st, 2011, 03:36 PM   #9
80mopar
Sic Ram
80mopar's Avatar
Old February 1st, 2011, 03:43 PM   #10
siczj
siczj's Avatar
I should add that he is the best bro ever. He bought me that badass inverter mounted in the back .
Old February 1st, 2011, 03:57 PM   #11
02trailblazin
02trailblazin's Avatar
nice zj
02trailblazin is offline   Reply With Quote
Old February 1st, 2011, 08:02 PM   #12
J Truck Rick
J Truck Rick's Avatar
Originally Posted by 02trailblazin View Post
nice zj
That's not just any zj,that's an Orvis edition,they were only built 2 or 3 years.Very rare Jeep!
J Truck Rick is offline   Reply With Quote
Old February 1st, 2011, 08:14 PM   #13
branch92
Only in a jeep
branch92's Avatar
did the orvis come factory with the 44?
branch92 is offline   Reply With Quote
Old February 1st, 2011, 10:58 PM   #14
siczj
siczj's Avatar
You are correct rick,Here's the production numbers
1995- 10,020
1996- 2,341 only 200 or less with 4.0
1997- 2,733
They came from the factory with a DANA 44HD or DANA 35 which are both weaker than the standard DANA 44. Mine came with the 35 but started making some bad noise. So i made a quick change to a 44hd (wish i would have just put a 8.8 in).
Old February 1st, 2011, 11:01 PM   #15
Jeep ZJ
Jeep ZJ's Avatar
is the 8.8 a bolt in??
Old February 1st, 2011, 11:37 PM   #16
siczj
siczj's Avatar
No,the 8.8 is FORD rear end.you need to transfer all the zj brackets (coil pads, upper,lower control arm and track bar) on to it after the ford brackets are removed. thin get the flange adapter for the drive shaft
Old February 3rd, 2011, 07:01 PM   #17
Jeep ZJ
Jeep ZJ's Avatar
k thanks. again really nice rig
Old February 4th, 2011, 11:58 PM   #18
branch92
Only in a jeep
branch92's Avatar
hmm well nice zj im still waiting on my 44 for my xj
Old May 29th, 2011, 10:59 PM   #19
siczj
siczj's Avatar
Just finished (5/29/11) a new rack with flip down lights and new slidders are now on!
Old May 30th, 2011, 09:14 AM   #20
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Should have cut out the stock rockers and put the sliders in their place, they're just gonna rot out and u would get a little clearance.
bitchofanxj is offline   Reply With Quote
Page generated in 0.38654 seconds with 83 queries
