94 LT1 question? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2011, 10:48 AM   #1
skife
skife's Avatar
Default 94 LT1 question?
Bought a 90 K5 blazer with a 94 lt1 in it. truck has been sitting for a few years and the header collectors have rotted off, it runs like crap mid range, it screams at WOT and idles nice.
Could it be something to do with the O2 sensors?
Old January 31st, 2011, 11:02 AM   #2
in2deep
Hole tester
yes at wot it does not use 02 it goes off the preprogramed fuel map in the ecm
Old January 31st, 2011, 12:15 PM   #3
toyota h8r
toyota h8r's Avatar
just part throttle issues? sounds like the opti spark is dumping on you
toyota h8r is offline   Reply With Quote
Old January 31st, 2011, 12:27 PM   #4
skife
skife's Avatar
opti was new when it was parked, was parked like 2 years ago though, outside, not on concrete. can the opti be cleaned or does it need to be replaced?
Old January 31st, 2011, 12:33 PM   #5
skife
skife's Avatar
also, should i be running premium in this?
Old February 1st, 2011, 10:16 AM   #6
toyota h8r
toyota h8r's Avatar
aluminum headed lt1? id run premium.....the iron one you could maybe get away with 89......hell i ran 87 in my 95 t/a once......it ran but just like crap though the rpm ranges
and no ya cant clean the opti-spark......once the sensor starts acting up its done. i replaced a lot of opti's and mainly were mid-range"popping/sputtering" or wouldnt get above 4000rpm and act like its on the rev limiter
Old February 1st, 2011, 10:33 AM   #7
TopGunn
Burried
TopGunn's Avatar
Send a message via AIM to TopGunn Send a message via MSN to TopGunn
Ahh the opti spark setup such a great design placed in A great spot! Lol
TopGunn is offline   Reply With Quote
Old February 1st, 2011, 05:48 PM   #8
mprmn08
mprmn08's Avatar
are the alum. headed ones alot higher compression or something? if there the same you can get away with less octane then a cast headed motor so why premium on alum and 87 would be fine on cast?
my buddys got a 95 t/a with an lt1 and he can run 89 just fine with the stock computer in. he can run 87 from some places but some places have shitty fuel and it wont run right. so i would 89.. 93 octane on a stock ecm is just a waste of money in my opinion. you dont necessarily get better performance from higher octane fuel unless you need it. high octane burns slower so it wont perform as well if you dont need it.
Old February 2nd, 2011, 06:52 PM   #9
skife
skife's Avatar
ECU is out of a '94 camaro, Don't know how stock it is.
Old February 2nd, 2011, 08:24 PM   #10
mprmn08
mprmn08's Avatar
just a thought but what about a knock sensor? pulling timing out at part throttle and makin it run like crap?
Old February 3rd, 2011, 09:01 AM   #11
skife
skife's Avatar
It could be that, but the headers have rotted off at the collector from sitting so long, the O2 sensors are in the exhuast behind the collector, so its automatically getting a lean single so it is getting more fuel than it should. its got a half tank full of 87 octane in it (could be causing spark knock and retarding the timing)
thats my theroy
Page generated in 0.50827 seconds with 56 queries
