*sold* lots of parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2005, 02:03 PM   #1
xj4life
xj4life's Avatar
Default *sold* lots of parts
Prices do not include shipping. All items located in Shelby Township, MI. I can get pics if needed.
(2) D30 Shaft set from a '98 XJ. Includes (2)inners, (2) outer stubs, questionable ujoints in one set and the other has one questionalbe and one that needs to be replaced. SOLD
(1) D30 Open Carrier for the higher numerical gears (4.88, 4.56,...) $50
(1) D30 Aussie locker, used for 4 months SOLD
(1) Set of Crane D44 Inner knuckles, ID 3.00", will not work with OEM 3" tubes. $250
(1) Set of RE SF2 Lower Adjustable Control Arms, P/N RE3715, paint was flaking so i started to remove bad paint but never finished, one is siezed and needs some tlc to be adjustable. SF joint seems okay SOLD
(1) Set of 4-door XJ Bushwacker Flares, i bought them used and never installed them, no sratches just a little dirty. hardware is there but i'm not sure its complete. SOLD
(5) Black steelies: like new condition, 5/4.5, 4" bs, i might have some center caps to go with them SOLD
xj4life is offline
Old December 8th, 2005, 03:56 PM   #2
xjmichigan
xjmichigan's Avatar
hey are those bushwacker flares for a 4 door xj ( half the flare gets mounted to the door and the other half )
i know you said no hardware, not even the rubber gaskets?
can i first dibs then
xjmichigan is offline
Old December 8th, 2005, 04:00 PM   #3
xj4life
xj4life's Avatar
ah yes forgot to add that. yes they are the 4 door version. not sure about the gaskets as i've never install these before. i believe they all do the the rubber trim that goes around the flair as it contacts the body. i can double check that though. as far as the hardware i have a small box of stuff just not sure if its all there.
xj4life is offline
Old December 8th, 2005, 04:02 PM   #4
xjmichigan
xjmichigan's Avatar
ok pm me later when possible about hardware and gaskets,
thanks,
alan
Old December 8th, 2005, 04:03 PM   #5
xj4life
xj4life's Avatar
thanks,
alan
i'll check tonight
xj4life is offline
Old December 11th, 2005, 09:06 AM   #6
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
Why don't they work on stock tubes?
h8pvmnt is offline
Old December 11th, 2005, 01:11 PM   #7
xj4life
xj4life's Avatar
because stock 3" tubes need the 2.950" ID version. i now know this from experience
xj4life is offline
Page generated in 0.24397 seconds with 44 queries
