Front GM 10 bolt ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2006, 10:23 PM   #1
Chop
Mischievous Badger
Chop's Avatar
Default Front GM 10 bolt ???
some crazy questions
i know that a D44 and a 10 bolt are very similar but will a front D44 carrier fit into a Front GM 10 bolt housing?
also i know that a rear GM 10 bolt has 30 spling shafts. so can i use the rear 10 bolt spyder gears for 30 spline and stick front Dana 44 shaft into a 10 bolt housing?
that should test ya
Old August 29th, 2006, 10:47 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
The D44 carrier will not fit in the 10 bolt. Why not just put the whole carrier in instead of just the spiders. I believe the hub on the 30 spline is bigger then the 28 spline. As far as the spline fitting it should. but I believe the shafts are short and long 1/2 between the dodge and a chevy. Find you a newer housing from a 88-90 suburban they will have 30 spline shafts in the front.
Old September 1st, 2006, 10:54 AM   #3
Chop
Mischievous Badger
Chop's Avatar
from what i have seen now. i can use gears, spools, spyders, carriers, all from a rear chevy 10 bolt 8.5 and it will fit and interchange with my front 10 bolt 8.5" .
am i correct?
Old September 1st, 2006, 11:07 AM   #4
PavementPounder
PavementPounder's Avatar
am i correct?
:tonka:
Old September 2nd, 2006, 01:31 AM   #5
Chop
Mischievous Badger
Chop's Avatar
Originally Posted by PavementPounder
:tonka:
:tonka:
Old September 2nd, 2006, 01:53 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
:tonka:
:tonka:
Old September 2nd, 2006, 11:31 AM   #7
PavementPounder
I have some backing plates I'll sell ya...
Old September 2nd, 2006, 11:57 AM   #8
KILLER"B"468
Yankabilly
am i correct?
Yes you will still need to match the length of your old 28 spline inner's to the new 30 spline inners. The outers are the same.
Page generated in 0.25221 seconds with 47 queries
