no dough high line - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2011, 06:30 AM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default no dough high line
WARNING!!! THIS IS NOT A SPELLING OR GRAMMER LESSON.
so i started to do "high line" fendes on my 98 tj.
pic 1(shittie i know, look at the time stamp) fenders are off. i started on the drivers side so i could just remove the 2nd battery tray and not fight it like i will have to do on the other side.
pic 2 i used tape to get the line i wanted, i started at th high part of the beval at the cowl and ended at the low side of the same body line near the hood latch.
pic 3 fangs. after looking at many pics of rigs without the 2k high line kit, there almost awalys a gap after you move the fender up. i going to try this but i don't no that it will work.
pic 4 no turning back now it took 4 harbor freight cutoff wheels to get both sides done.
next i have to mark the new hole locations to match the inserts on the body.
ID:	73910   Click image for larger version
ID:	73911   Click image for larger version
ID:	73912   Click image for larger version
luvitmyjeep is offline   Reply With Quote
Old January 30th, 2011, 06:33 AM   #2
luvitmyjeep
broken
not mine, but thats the gap i was talking about.
Old January 30th, 2011, 06:47 AM   #3
luvitmyjeep
broken
pic1 maybee this wasn't such a good idia, this should fix it.
pic2 bracket and tray off.
pic3 new holes marked and ready to be drilled.
pic4 this was the best way i found to hold the fender while i drilled.
ID:	73915   Click image for larger version
ID:	73916   Click image for larger version
ID:	73917   Click image for larger version
Old January 30th, 2011, 08:06 AM   #4
dentedvw
╭∩╮ 0_o
dentedvw's Avatar
Oooooh. Can't wait to see it finished. I think about this now and again, but I will probably wait until I have mashed the fender a few times.
dentedvw is offline   Reply With Quote
Old January 30th, 2011, 08:45 AM   #5
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
I did the same thing and so far I love it. Instead of drilling new holes, I reused the old ones and drilled 1 new one at the bottom. How did you handle the latches? The TJ latches were a PITA to work with, and although I got it, I might do YJ/CJ latches in the future. I didn't to a write-up but here are a couple of pics in case anyone is interested in doing it...
Sorry for the Hijack, thought it might help someone out trying to decide if they want to tackle the project!
Now back to your regularly scheduled programming.
TechJeeper is offline   Reply With Quote
Old January 30th, 2011, 09:04 AM   #6
luvitmyjeep
broken
after i drilled the holes to line up with the body, i put a level on the fender and put a self tapper in it to hold it in place.
pic1 i'll have to trim this part down to keep the curve of the hood.
pic 2 getting closer,
pic 3 i'll have to trim some more of of pic 1. it will be close but it doesn't look like it will fill it. i have a plan.
ID:	73921   Click image for larger version
ID:	73922   Click image for larger version
Old January 30th, 2011, 09:25 AM   #7
Offroadian
seasoned
I like your idea of no gap.
Offroadian is offline   Reply With Quote
Old January 30th, 2011, 09:53 AM   #8
luvitmyjeep
broken
that looks good!
hi-jacks are welcomed here. the more ideas the better.
as far as the latches go, i think i'm going to use pins. they are a pain.
what did you use for the "molding/weatherstripping? i found some that goes on the outside of doors and such, but it's only 1/4 i would like somthing 3/4 or so to really seal it.
Old February 7th, 2011, 09:08 AM   #9
TechJeeper
TechJeeper's Avatar
Originally Posted by luvitmyjeep View Post
that looks good!
Not sure if you figure something out yet, but I bought some from some edge molding from Advanced Auto Parts, its really nice, it has adhesive in the slit so once its put on and let set, it sticks really well.
Old February 10th, 2011, 04:38 PM   #10
luvitmyjeep
broken
i got to do a bit more today. the fenders lay level both ways so, so far im 8/10 happy with it.
i will have to pin the hood tho.
now it's time for the other side.
ID:	74334   Click image for larger version
ID:	74335   Click image for larger version
Old February 28th, 2011, 07:43 PM   #11
hotwired
That looks really nice, got any more pics? Oh, by the way, when the Hell do you sleep?
hotwired is offline   Reply With Quote
Old March 1st, 2011, 05:24 AM   #12
luvitmyjeep
broken
thanks! the otherside is done but i need batteries. as far as sleep goes, it's hard for me to stop sometimes. it the only bad part about an attached garage.
Old March 1st, 2011, 09:48 PM   #13
Offroadian
seasoned
Why would you need to pin the hood?
Just remount the latch, or if you don't like the look,
what about moving the whole thing back on the fender a little.
Old March 2nd, 2011, 05:13 AM   #14
luvitmyjeep
broken
i still might.when they are attatched they are at a real goofie looking slant becuase i cut off more than most right there. pluss it looks like it might get in the way of my tubefenders. not real shure what the design of those just yet..
Old April 6th, 2011, 07:36 AM   #15
luvitmyjeep
broken
well now i'm back to the not so fun parts.
problem #1 i cant get the battery tie downs to work.
#2 i need to find a smaller wiper fluid res. i was thinking somthing from a rear window?
#3 air box.
anyone have any ideas?
Old April 8th, 2011, 11:25 AM   #16
luvitmyjeep
broken
did some problem solving.
pic1 i ended up with all kinds of gaps and ugly after i had it all to geather, so... befor
pic2 after... i made some patch panals,
next was the fuse box
pic3. i seperated the two bracket and made two of my own
pic4 slid it all back togeather.
pic 5 mounted it to the fender well.
ID:	77118   Click image for larger version
ID:	77119   Click image for larger version
ID:	77120   Click image for larger version
ID:	77121   Click image for larger version
Old April 8th, 2011, 11:35 AM   #17
luvitmyjeep
broken
next was the batbox
pic1 it all goes back to stock holes and hardware.
pic2 it hangs down adout 4 inches so i had to make a cover.
pic3 & 4 the new look.
ID:	77124   Click image for larger version
ID:	77126   Click image for larger version
ID:	77128   Click image for larger version
Old April 8th, 2011, 11:16 PM   #18
Offroadian
seasoned
Looks Great!
Old April 9th, 2011, 07:10 AM   #19
luvitmyjeep
broken
i cant get a good pick fron the front because it to close to the wall
i hope to get the front done today so i can pull it out and clean the garage!
ID:	77166   Click image for larger version
Old April 23rd, 2011, 08:58 AM   #20
luvitmyjeep
broken
a better pic. i got ti out of the garage long enough to clean and find out the new motor is junk. so now i get to tare it all back apart
Page generated in 0.36851 seconds with 84 queries
