want info on big lift kits for 96 2500 cummins - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2011, 07:14 PM   #1
red87chevy
red87chevy's Avatar
Default want info on big lift kits for 96 2500 cummins
were can i find a 8 or 10in kit for my 96 cummins looking all over hell but no luck!
HELP!!!!
red87chevy is offline   Reply With Quote
Old January 27th, 2011, 07:25 PM   #2
Flat_Black
The Dodge Guy
Flat_Black's Avatar
skyjacker makes a 7" long arm or short arm
i can get a 8" kit from pure performance for around 2900
Pure Performance 95-02 Dodge Ram 3/4 Ton 8" Coil Over Prerunner System
The 8.0" PreRunner System for the Dodge Ram 2500 4x4 is flat out Awesome! This system is a full featured long arm system featuring adjustable lower control arms made from 2" solid alloy steel and adjustable upper control arms made from 1 5/8 solid alloy steel. This PreRunner System also features massive 2 5/8" - 10" travel Pure Performance coil overs to soak up bumps and provide excellent ride quality like no Dodge system has ever done! To ensure proper steering geometry we give a heavy duty track bar bracket made of 1/4" thick steel with a double adjustable front track bar made from 1.5" solid alloy steel and a drop pitman arm. The PreRunner system features a conventional back end. This system comes with our exclusive abuse proof lifetime guarentee which the competition can't match! System Benefits:
1) Massive 2 5/8" - 10" travel Pure Performance coil overs.
2) Adjustable Control Arms!
3) Better highway ride quality and response than any other system on the market!
4) Offroad performance that can't be beat!
5) Allows for 37" x 12.5" tires with no fender trimming.
6) Exclusive abuse proof lifetime guarentee on all hard parts.
System Includes:
(2) 2 5/8" - 10" travel Pure Performance coil over shocks, (2) linear front coil over springs, (2) upper coil over mounts made from 1/4" thick laser cut steel, (2) lower coil over mounts made from 1/4" thick laser cut steel, (2) long arm brackets made from 1/4" thick laser cut steel, (2) adjustable lower control arms made from 2" solid alloy steel, (2) adjustable front upper control arms made from 1 5/8 solid alloy steel, (1) double adjustable front track bar made from 1.5" solid alloy steel, (1) track bar bracket made from 1/4" thick laser cut steel, (2) double adjustable sway bar end links, (1) drop pitman arm, (2) rear lift blocks, (4) rear u-bolts, (1) rear stainless steel brake line, hardware and detailed instructions.
Old February 7th, 2011, 08:19 PM   #3
red87chevy
red87chevy's Avatar
bump
anyone kno of anything else?
Page generated in 0.21180 seconds with 32 queries
