Interim Jeep daily driver ($1200 or less) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2011, 12:17 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default Interim Jeep daily driver ($1200 or less)
We have a compression/cylinder head issues (2 cylinders) with a 2005 Liberty with only 115K miles (teh suckness!). Instead of having a knee-jerk reaction and paying the dealership $2200 to machine the heads, I wanted to see what was out there for an interim daily driver while we figure out a plan for the Liberty repair or replacement. Looking at Jeeps only at this point...likely a Cherokee at this price point.
Interested in something in the Grand Rapids area, unless it's someone I know on the East side (in which case traveling may be an option).
What do you have?
Craig
Old January 27th, 2011, 07:27 PM   #2
ssjeepfreek
ssjeepfreek's Avatar
Hi Craig,
Just ran into the same thing with buddies, only he lost oil pressure and you can guess the rest. Dealer wanted big bucks. We ended up picking up a motor at the junkyard, I mean recycle center for 750.00. Had 80k on it an looked maintained. He has put about 30k on it with no issues. Had a weekend into the swap and I think he got something back for the old motor. Just a thought, good luck.
ssjeepfreek is offline   Reply With Quote
Old January 27th, 2011, 07:53 PM   #3
hanser
hanser's Avatar
Pull the valve covers & make sure the cam followers didn't fall out. I don't know for sure if it happens on the 3.7, but I have seen it on the 4.7 V8, which the 3.7 is based on. Cam followers are sort of like a rocker arm, they have a roller that rides on the cam and they push the valve open. When they fall out, the valve doesn't open, so no compression. You might get away with just compressing the valve spring and sneaking them back in place.
hanser is offline   Reply With Quote
Old January 28th, 2011, 04:52 AM   #4
1x1_Speed_Craig
Simplify...
Thanks for the input, guys. Those are the kinds of things we want to consider checking into, but would need a daily-driver in the meantime.
Nobody? (Actually, I did receive one PM, and am looking into that.)
Craig
Old January 29th, 2011, 04:56 PM   #5
1x1_Speed_Craig
Simplify...
No longer necessary...she traded her Liberty in and got a sexy 2011 JK today.
Old January 29th, 2011, 11:33 PM   #6
gmotox
gmotox's Avatar
Sweet JK Craig..
But it needs J8 axles under it
Old January 30th, 2011, 03:00 AM   #7
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
didn't see that coming !
Old January 30th, 2011, 07:36 AM   #8
1x1_Speed_Craig
Simplify...
Originally Posted by gmotox View Post
Sweet JK Craig..
While she trusts me fully, Amy would beat me if I took the wrenches to her less-than-24-hour-old JK. (but yes, it would be cool )
Craig
Page generated in 0.31424 seconds with 47 queries
