any one have a idea ???????????? tracker need help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2011, 12:46 AM   #1
aron1234
aron1234's Avatar
Default any one have a idea ???????????? tracker need help
k i have a 91 tracker had pluged fuel lines cleaned them ran great. drove it into the yard and just died the gauges/lights died. have power to everything else like radio heat exc still turns over but wont fire any one have this problem ????
aron1234 is offline   Reply With Quote
Old January 27th, 2011, 01:03 AM   #2
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
If you have spark and fuel pressure but no fuel out of the injectors it is the computer. Common problem with trackers.
spr_chicken is offline   Reply With Quote
Old January 27th, 2011, 01:25 AM   #3
aron1234
aron1234's Avatar
i have fuel have it hooked up on a switch ....everything works just nothing at the gauges and just turns over ....
Old January 27th, 2011, 01:27 AM   #4
aron1234
aron1234's Avatar
thought maybe a ground wire came off but everything looks good ??
Old January 27th, 2011, 01:45 AM   #5
spr_chicken
If you have a bad computer. You will have fuel pressure but the injector will not fire.
When mine went bad I had just pulled up to a drive thru window. I shut the tracker off because it was loud. When I went to restart it it just spun over. It had spark and fuel pressure. Just would not let the injector fire.
Old January 27th, 2011, 11:20 AM   #6
aron1234
aron1234's Avatar
and u think that would kill the gauges also like the 4x4 light dont come one or any of that stuff dont work .... and what one is it the little black box on fire wall under dash or i seen asliver up inside the dash .. thanks for your info
Old January 28th, 2011, 04:34 PM   #7
A4X4SPIT
A4X4SPIT's Avatar
well this might sound stupid but did you check the fuses there are some big fuses under the hood one main and several others Id get a test light & start checking do you have power to & from fuses? do you have power to fuel pump &main relays ? does the fuel pump run like its supposed to ?if not is there power when its supposed to be on? is the is it a 1.6 16valve mfi or a 8v throttle body? if the fuel getting to the throttle body or furl rail ?will it start if you spray starting fluid in the throttle body? if the fuel pump is on a switch somethings not right it should be controlled by the ecm & relay
does it have spark? is there power to the coil /distribitor I would check a bunch of things before I replaced the computer
A4X4SPIT is offline   Reply With Quote
Old January 28th, 2011, 05:33 PM   #8
aron1234
aron1234's Avatar
yeah i checked all the fuses there all good fuel pump works i have that ran on its own switch .didnt check spark yet but it has noting at the gauges so dont what would cause that ..any of the relays under the dash control that??
Old January 28th, 2011, 07:13 PM   #9
A4X4SPIT
A4X4SPIT's Avatar
maybe the main relay.. me Id check for spark before I worried about the gauges they may be the same problem if there's no spark is there power to the ignition sw & going out when on ? Ive had mystery issues like this before & just had to keep chasing things down & you'll find its a unplugged /broken wire/plug or a bad relaykeep at it youll get it good luck
Old January 29th, 2011, 12:44 AM   #10
aron1234
aron1234's Avatar
ok thanks for the tips ill let u know what i come up with
Page generated in 0.24347 seconds with 53 queries
