Minimum rim size on 3/4 ton Ford? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2011, 09:51 PM   #1
slvrlake survivor
It Aint Cheap to Jeep.
slvrlake survivor's Avatar
Default Minimum rim size on 3/4 ton Ford?
Whats the minimum rim size needed to clear 3/4 ton brakes?
I have a D44 from a 78 F250, I put my 1/2 ton brakes on it and discovered the calipers hit the 3/4 ton knuckles. I have 15 inch rims and i need to know if they will clear 3/4 ton brakes??(if i go that route) I need some sort of brake setup, but im having trouble finding a solution... any tips?
I heard i can use ford knuckles from a 77-79 F150 super-cab (i believe their the only ford 1/2 ton knuckles which are flat top so i could run my high steer and my brakes will fit) Problem is these knuckles are probably damn near impossible to find.
slvrlake survivor is offline   Reply With Quote
Old January 26th, 2011, 09:55 PM   #2
MiNi Beast
MiNi Beast's Avatar
16's
or grind calipers and run 15s
Old January 26th, 2011, 09:55 PM   #3
MiNi Beast
MiNi Beast's Avatar
or 15s with 2" bs
Old January 26th, 2011, 10:16 PM   #4
slvrlake survivor
hmmm Im thinkin i may grind the calipers. Does it require quite a bit of grinding to get the clearance i would need?
Old January 26th, 2011, 10:33 PM   #5
MiNi Beast
MiNi Beast's Avatar
yep, grind till they fit. do it with caliper on, if grind to much caliper will fall off.
Page generated in 0.19123 seconds with 38 queries
