Coolant hose issue on a 1992 460 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2011, 11:43 AM   #1
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Default Coolant hose issue on a 1992 460
I am working on a 1992 F250 with the 460 in it. It is leaking coolant from what appears to be the short elbowed hose from the water pump to what I believe is called the heat exchanger. The oil filter adapter is bolted to it. How in the hell are you supposed to replace the hose without removing the water pump or the exchanger?? It does not appear to be possible.
I finally cut the old hose off, and between the two ends is only about 3/8" clearance to get the hose back on. Any of you Ford Guru's have a good way to replace this?? Thanks
Old January 26th, 2011, 04:21 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
spray silicone.
if your talking about the short hose between the pump and intake. its a bitch but can be done.
Yetti
Old January 26th, 2011, 04:33 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by Yetti View Post
spray silicone.
x2 its a pita
H.o.r.e
Old January 26th, 2011, 04:52 PM   #4
Ridin Dirty
No, from the bottom of the pump to the heat exchanger/ oil cooler piece of shit. There is only about a 3/8" gap between the 2 pipes to fit the damn hose on.
Page generated in 0.27157 seconds with 35 queries
