5mpg and no codes!!!!(2000 zr2) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2011, 01:13 AM   #1
toyota h8r
toyota h8r's Avatar
Default 5mpg and no codes!!!!(2000 zr2)
hey all,
my truck tore apart waiting for parts stores to open
but my 2000 zr2 is getting close to 5mpg and im fed up
so far ive done;
--cap/rotor
--ac-delco platunum plugs
--ac-delco wires
--new TB
--IAC replaced
--IAT replaced
--fuel pump
--fuel filter
--ign coil
--ign module
So i started tearing the top end of the intake apart to see MOST of my o-rings had been leaking and i found dirt on my fuel pressure regulator!!!! The spider assembly had RTV around it so it would seal to intake
The MAP sensor was really loose but other than these issues i dont see puddling of fuel or even pressurized nothing drips.
I ran my diagnostics tool on it and all sensors are reading correctly and within specs.......The oxygen sensors are working correctly also.
The truck has 113,xxx miles and is tore down to this point, do i man up and buy the 299.95 MPFI conversion from local autostore????? ALSO a new regulator?
PLEASE help me!!!!!!!!!!!!!!! i cannot afford to drive my truck now and its my only ride to work right now
toyota h8r is offline   Reply With Quote
Old January 26th, 2011, 01:17 AM   #2
toyota h8r
toyota h8r's Avatar
parts i have replaced:
--MAF
--MAP sensor
--fuel pump(gauge still shows 41-51psi......)
--fuel filter
--air filter
--MPFI KIT(replaces JUNK spider setup)
--spark plugs
--wires
--cap/rotor
pretty much everything but o2's(autozone was out)
My hand held scanner shows o2's are pretty quick and responsive but teh ECU is adding fuel on BANK 2 and wont go under 20* of advance at idle....
Old January 26th, 2011, 02:00 AM   #3
370
370's Avatar
autozone electrical parts
370 is offline   Reply With Quote
Old January 26th, 2011, 02:15 AM   #4
toyota h8r
toyota h8r's Avatar
well.......then bosch sucks......
thats all i ever used for o2's.......
Old January 26th, 2011, 05:43 AM   #5
Disturban
Disturban's Avatar
Originally Posted by toyota h8r View Post
--new TB
What kind of new Throttle body? Is it stock and if so do you have the air diffuser on the blade? A lot of people who own S10's think this is some kind of restricter but it is not, it is designed to eliminate low pressure zones inside the manifold that without it will cause lean conditions on certain cylinders.
The MPFI conversion is probably the very best mod you can do on a S10, it eliminates the poppet valves, the poppet valves are notorious for getting stuck either open or closed, with what you describe I would guess you have one or more on a bank that is stuck open, the computer see's the motor is running rich and trims the fuel. With the computer trimming the fuel the side that has stuck poppet valves is getting the right amount of fuel however the other bank is now running lean.
Another possibility is lower intake manifold leak causing one bank to run lean and the computer is trying to compensate for it by adding more fuel.
Old January 26th, 2011, 12:42 PM   #6
toyota h8r
toyota h8r's Avatar
i just wish i knew how to read my scan tool.......from what i gather the o2's are not reading right and causing the ecu to dump fuel
im getting anywhere from -7.8 to -10% fuel. From what ive read the negative numbers mean the ecu is enriching the mixutre
Old January 26th, 2011, 12:49 PM   #7
davidkassie
davidkassie's Avatar
short term fuel trim, -% means ecu is taking fuel to correct for rich mixture, +% means ecu is adding fuel to correct lean mixture
davidkassie is offline   Reply With Quote
Old January 26th, 2011, 12:58 PM   #8
toyota h8r
toyota h8r's Avatar
yah i was thinking thats what it meant.....also im getting 7.8-8.4% fuel on Long term fuel cell on eway...is that right????
also i noticed my ign advance being weird, all the cars/trucks ive scanned they read negative(retard) at low driving and then full advance at WOT. My truck does some weird crap. At idle it bounces from 18*-20* and under light accel it shoots to 38*. The odd part is under WOT the advance pulls back to 21-23* of timing
Of my driveway:
96 z71(8.4" of vacuum)
01 xtreme(9" of vacuum)
00 sonoma(mine)(10.9" of vacuum)
They all have lower vacuum at idle and get better gas mpg.......only thing left to change is the o2's on the truck and hope to god it fixes it
Old January 27th, 2011, 02:36 PM   #9
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Quit throwing parts at it,and go have it properly diagnosed.
IFS SUCKS is offline   Reply With Quote
Old January 27th, 2011, 02:51 PM   #10
Freak
Wheelin the HD
Freak's Avatar
X2 just because you take it in to get diagnosed does not mean you have to let them fix it.
Old January 27th, 2011, 02:56 PM   #11
IFS SUCKS
I like trees
IFS SUCKS's Avatar
More times then not people come into my dealership after throwing hundreds of dollars at their car,and we end up finding stupid shit like a broken wire.
Old January 27th, 2011, 04:06 PM   #12
booblinker
Sore and Tired 24/7
booblinker's Avatar
unless I missed it, I see no coolant temp sensor? If you can get ahold of a scanner that does live data, when it is cold see what the coolant temp is, if it doesn't read what temp it is outside, and reads way laower, it is bad and won't always show up as a check engine light.
Old January 28th, 2011, 08:18 AM   #13
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'd check the rear bumper to see if there's a 26' travel trailer back there.
Tell me about your exhaust system - stock?
If you're running in closed-loop, not setting any fuel trim codes (that indicate you have a huge fuel leak into the intake and the ECU is pulling the max amount of fuel out and you're still rich), then it is not fuel related.
Next, your timing sounds about right - it runs off a speed/load map and can look goofy at times.
I'd be interested in what your exhaust backpressure is.
@clarkstoncracker
Page generated in 0.66101 seconds with 62 queries
