chevy d44 and d60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2011, 09:23 PM   #1
dmkx3
grave digger
dmkx3's Avatar
Default chevy d44 and d60
i might have the chance to buy a front d44 and a rear d60. both are out of a 89 full size blazer. my question is are these worth buying and modifing to fit under my tj???
dmkx3 is offline   Reply With Quote
Old January 24th, 2011, 09:28 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
chevy has a passenger drop front your tj is driver drop, it can be made to fit but way too much work for not that much strength gain in the front
Old January 24th, 2011, 09:31 PM   #3
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Ummm D60 rear was not an option in a 89 Blazer not to mention Chevy used Eaton and corp 14 axles not the d-60 rears. Get a HP 44 or 60 front from a Ford. A rear 14 bolt or 60 would work fine if you don't mind the width difference from stock.
Page generated in 0.19700 seconds with 32 queries
