1983 Scrambler build: 5.3 / TH350 swap - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2011, 07:41 AM   #21
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
pming you about LEDees.
@clarkstoncracker
Old January 27th, 2011, 11:34 AM   #22
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Subscribed. Nice work so far.
Old January 27th, 2011, 07:11 PM   #23
Got a big box of goodies from summit and my harness came back today.. pics forthcoming after I put 3 little kids to bed....
Old January 27th, 2011, 08:19 PM   #24
So, here's parts I got today:
Torque converter and trans shift kit:
gauge adapter and adpater for the torque converter to fit the 5.3 flywheel...
Shifter:
Blazer motor to modify the heater box..
Got some scraps from work (parts from a chevy volt and dodge ram) which I will cut up to make indicators like turn signals and high beam.
ID:	73787   Click image for larger version
ID:	73788   Click image for larger version
ID:	73789   Click image for larger version
ID:	73790   Click image for larger version
Old January 27th, 2011, 08:29 PM   #25
Got my harness and ECU from Jims performance, really happy with it, and he's very easy to work with and thorough.
Every sensor is labelled clearly. All unneeded wires are gone. Stuff like the downstream O2 sensors and such are gone. Each injector connector is marked for its cylinder.
A new fuse block is added to supply power to the ECU, fuel pump, injectors, everything.
The harness is simple plug and play. Hook up the harness to the engine, hook up battery, ignition, ground. There are wires to the starter, fuel pump, tach output, two electric fan triggers, and check engine light. A diagnostic connector has also been added to install under the dash.
The ECU has been reprogrammed with a 'mail order' tune, and to eliminate stuff that I don't want, like the transmission programming, downstream O2s, secruity, etc.
Glad I did it, it would have taken me a week to get the harness this nice, and still would have needed to add stuff like the diag connector and fuse block, and sen out the ECU for reprogramming.
ID:	73792   Click image for larger version
ID:	73793   Click image for larger version
ID:	73794   Click image for larger version
Old January 27th, 2011, 09:07 PM   #26
Hillbillydelux
Hillbillydelux's Avatar
The harness turned out really nice! I have one here I need to send out, what did it cost you and how long did it take? I have a YJ in my garage with another company's harness on it...im not impressed.
Hillbillydelux is offline   Reply With Quote
Old January 27th, 2011, 09:16 PM   #27
pizzaman
pizzaman's Avatar
Nice build so far Jason. I was wondering when you were going to start this. PM sent!
pizzaman is offline   Reply With Quote
Old January 27th, 2011, 09:30 PM   #28
He did it in about 1.5 weeks (he's in Maryland).. cost was $350 to do the harness.
I also send him my drive by wire pedal, TAC module, everything, and he powers it up and checks it all out.
Old January 27th, 2011, 09:34 PM   #29
Hillbillydelux
PM'd
Old January 28th, 2011, 08:01 AM   #30
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Shit.
I gotta set myself up to do that. HE provides one heckofa service!
@clarkstoncracker
Old January 28th, 2011, 09:10 AM   #31
Shit.
Its one of those things that I could do it just fine, I can get schematics, I have all the pinouts actually. I can do the crimping, everything. But it takes time. I have a 5yr old, 2yr old, and 5mo old, busy work schedule, etc, so I get about 6 hours a week to work on this, and there's better use of my time. Glad I decided to farm it out...
Old January 28th, 2011, 09:27 AM   #32
John D
John D's Avatar
Looks good so far.
You're right about the harness; it's not rocket science but it is time consuming.
When do you think you will be done (done meaning drivable again)?
Old January 28th, 2011, 09:36 AM   #33
bigbchevy
missmrgreenagain
bigbchevy's Avatar
badass build !
H.o.r.e
Old January 28th, 2011, 11:45 AM   #34
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I know what you mean, but what if you were part of a startup company that did this sort of thing on a larger scale, catering to all kinds of enthusiasts?
I keep playing the lottery so that maybe I can start that company.
@clarkstoncracker
Old January 28th, 2011, 12:11 PM   #35
Originally Posted by John D View Post
Looks good so far.
I am targetting going to Drummond Island in early April. But we'll see, my work schedule is getting busy and I have a lot of international travel coming up....
Old January 28th, 2011, 12:32 PM   #36
John D
John D's Avatar
Ugg, I know about that. Friggin work trips keep getting in my way of projects too.
Old January 28th, 2011, 01:32 PM   #37
liv2mx
i like jungle gym's.
liv2mx's Avatar
yep i will agree, that is the way to go on the harness. looking like the parts list is getting smaller.
Old January 28th, 2011, 02:34 PM   #38
DD04WJ
aka OutsideFamily
DD04WJ's Avatar
Looking good... I totally agree with farming out some of the work.
DD04WJ is offline   Reply With Quote
Old January 29th, 2011, 05:13 PM   #39
Hmm, today was supposed to be a work day, but its slipping away on stupid other things.
I did get my central dash layout done. Hopefully tonight I can start sanding and painting the dash. I cut a piece of steel to fill the spot on the dash where the original gauges and a cutout for a radio were.
The tach will go in a pedestal mount on the steering column. The switches will control rock lights, front driving lights, rear backup lights, and one spare. If I can't think of anything else, I'll use it to power the amp. I'm going to put a small 4 channel amp somewhere in there, and just use an MP3 player as the 'radio'. The flat area in the upper right can't really be used, because the defroster duct is back there really close to the dash. Those are two power outlets on the bottom right.
Old January 30th, 2011, 04:27 PM   #40
Got a few minutes to work today (sadly, a 'few' is pretty accurate...). So I finished the dash plate. I transfered all the marks to a piece of MDF that I cut to exactly the same size as the metal plate on a table saw. Sheet metal warps and grabs bits if you try to drill it on its own, so I sandwich it between two pieces of MDF, and drill through the top board and the metal. Comes out nice and flat.
Here's the drilling. Nice to have the XY table on the mill, you can get everything lined up and drilled nice and straight.
Here's the panel done..
... and fillled...
ID:	73950   Click image for larger version
ID:	73951   Click image for larger version
Tags
jesus_kills_another
Page generated in 0.62036 seconds with 84 queries
