Front bumper & Tire carrier pics - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2011, 09:57 PM   #1
itchy
itchy's Avatar
Default Front bumper & Tire carrier pics
Been workin on my bumpers and tire carrier for the TJ. Figured I'd post up some pics of what I've got done. Would like to see what everyone else is building too. Lets see some pics of your bumpers and tire carriers.
I needed to come up with something that would raise my winch off the frame a few inch's to clear the gear box that was raised on the frame rail. The front crossmember is a 3X4 inch tubing that was angled in the middle. Wanted something other than just a square tube up front.
If this should be in the build threads, then feel free to move it. Just figured it would fit in the fabrication section.
Name:	black tj 016.jpg
ID:	73567   Click image for larger version
Name:	black tj 017.jpg
ID:	73568   Click image for larger version
Name:	black tj 018.jpg
ID:	73569   Click image for larger version
Name:	black tj 019.jpg
ID:	73570   Click image for larger version
Name:	black tj 020.jpg
Name:	black tj 021.jpg
ID:	73572   Click image for larger version
Name:	black tj 022.jpg
itchy is offline   Reply With Quote
Old January 23rd, 2011, 09:59 PM   #2
itchy
itchy's Avatar
And the rear carrier was made from 1 1/4 inch round tubing, with the main support mount being 1.5" 1/4" wall. I used 3/4" chromoly rod ends for the mounts at all for corners. And after making all those brackets, and coping all that tubing I really miss cutting my lawn.
Name:	black tj 023.jpg
ID:	73575   Click image for larger version
Name:	black tj 024.jpg
ID:	73576   Click image for larger version
Name:	black tj 025.jpg
ID:	73577   Click image for larger version
Name:	black tj 026.jpg
ID:	73578   Click image for larger version
Name:	black tj 027.jpg
Name:	black tj 029.jpg
ID:	73580   Click image for larger version
Name:	black tj 030.jpg
ID:	73581   Click image for larger version
Name:	black tj 031.jpg
Old January 23rd, 2011, 10:04 PM   #3
orionorion
orionorion's Avatar
Sweet! I like it. You've done some nice work there!
orionorion is offline   Reply With Quote
Old January 23rd, 2011, 10:06 PM   #4
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good. I like the front bumper. Good to see something different from the norm.
Old January 30th, 2011, 02:01 PM   #5
OttoMan
OttoMan's Avatar
did you have to reinforce the passenger side rear quarter? if so do you have pics of the inside and how you did it?
OttoMan is online now   Reply With Quote
Old January 30th, 2011, 09:14 PM   #6
littletrucker
I'd hit that
littletrucker's Avatar
Here is what i made for my front bumper- I like the narrow not sticking past the frame look.. If the fenders get messed up ill do something different with them
Old January 31st, 2011, 11:57 AM   #7
kickstand
circling the drain
kickstand's Avatar
holy stinger thing
Old January 31st, 2011, 06:32 PM   #8
littletrucker
I'd hit that
It looks bigger in pictures
Old February 4th, 2011, 11:26 PM   #9
itchy
itchy's Avatar
The body has 3/16th's steel armor bolted to the qtrs. I think it would be fine, but I am going to run a brace from the qtr to the cage on each upper mount.
Old February 5th, 2011, 12:12 AM   #10
OttoMan
OttoMan's Avatar
would you be willing to post pics of that? i am interested in doing something like this in the future for a truck and am worried about flex.
when i was younger i had a bronco that flexed since alot of stuff was rotted through.
i always liked the look of that spare on the back. i know that there are bumpers available but i like to see all options and different methods.
Old February 6th, 2011, 08:34 PM   #11
itchy
itchy's Avatar
Sure I can put a few pics up when I get to that point. Im still a few weeks away from starting the cage, so it will be a bit before I get to the brackets.
Old February 7th, 2011, 03:17 AM   #12
OttoMan
OttoMan's Avatar
that's cool. thank you,
Page generated in 0.38500 seconds with 60 queries
