How to know if its a 4 bolt main??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2011, 11:02 AM   #1
haulincats
haulincats's Avatar
Default How to know if its a 4 bolt main???
I am looking at buying a 1984 Chevy 350 small block from a pick up.
Is there any numbers on the block that will tell me its a 4 bolt main?
If so what would they be? I don't really want to pull the pan.
Thanks,
Vance
haulincats is offline   Reply With Quote
Old January 23rd, 2011, 11:44 AM   #2
insane88yj
insane88yj's Avatar
Check the #'s on pass rear of block is how to tell. google SBC block id & make a copy of id #'s to take with you. Some times though they ues same #'s for 2 & 4 bolt mains.
Sorry to say but best way to tell forsure is to pull pan.
insane88yj is offline   Reply With Quote
Old January 23rd, 2011, 11:51 AM   #3
skife
skife's Avatar
84 is probably a 2bolt, really doesn't matter though unless you plan on spinning 7,000+
just drop the pan.
Old January 30th, 2011, 03:37 PM   #4
michigan maniac
michigan maniac's Avatar
ive heard if there is a small square plug up by the water pump that it is a four bolt main, mine has one but im not sure if its true
Old January 30th, 2011, 03:41 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
its not, that square plug is a oil feed from the lifter run. it comes on all of them.
the letter code stamped in the right hand front block boss next to the water pump has the coding for the type of engine application. other then that all blocks come from the same mold as far as castings are concerned. you can't tell without looking.
Yetti
Page generated in 0.16278 seconds with 38 queries
