1/2 ton brakes on 3/4 ton? Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2011, 07:03 PM   #1
slvrlake survivor
It Aint Cheap to Jeep.
slvrlake survivor's Avatar
Default 1/2 ton brakes on 3/4 ton? Help
I started with a dana 44 1/2 ton bronco axle which had a bent housing. I bought a 3/4 ton housing from an f250 and put the 1/2 ton caliper brackets on it. The 1/2 ton caliper brackets looked correct on the 3/4 ton setup, but when i tried to put the 1/2 ton calipers on, they just hit the knuckle and just dont sit right.
1) Is there any way to make this work?
2) If i go to the 3/4 ton brake setup, can I still use my 15" rims?
slvrlake survivor is offline   Reply With Quote
Old January 22nd, 2011, 07:29 PM   #2
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I ran into the same problems as you and even tried to grind down the calipers. If there was a way to make it work, I never found it. I just decided to run the 3/4 ton brake setup and at least you get the dual piston style caliper. I believe you can grind the calipers down to run a smaller size wheel, but if you can't/don't the smallest size is 16.5" I believe.
*2007 Rubicon
*2006 Duramax
Old January 23rd, 2011, 12:01 PM   #3
slvrlake survivor
well that sucks... sounds like im gonna have to find new rims and tires..
Old January 23rd, 2011, 01:23 PM   #4
slvrlake survivor
I'm thinking if i get some chevy 1/2 ton knuckles (flat top), and spindles, i could use my 1/2 ton ford brake setup. The chevy knuckles are small and theirs a radius for a caliper to fit on it. And i would still be able to use my high steer.
Old January 23rd, 2011, 09:14 PM   #5
OnlyInMyXJ22
No Money = No Fun
Oh yeah, I forgot about the option of using Chevy stuff. I decided against that as it was easier to run all Ford stuff.
*2007 Rubicon
*2006 Duramax
Old January 28th, 2011, 12:24 PM   #6
slvrlake survivor
well i solved the issue, it was nothing some grinding couldnt fix. ground on both the caliper and the knuckle and it worked out.
Page generated in 0.21241 seconds with 41 queries
