D70 drw - disk brake help - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2011, 01:42 PM   #21
Pokerob
hug life
Pokerob's Avatar
Got the rear end put together after i had a slight problem. Due to the D70 having larger studs which obviously makes the hub have a larger opening which is too big for the the studs from a 60 to work.
So I had to open the holes on the rotors (late 70's Chevy 3/4 ton) a tad to fit the bigger shoulder of the new studs so they would fit.
here it is, ready for some mounts, links and I need to also burn the Caliper brackets in as they are just bolted in right now with smaller bolts since the bracket is for a GM axle and mine is a Dodge so the holes only match up slightly and not perfectly.
Page generated in 0.26156 seconds with 26 queries
