D70 drw - disk brake help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2011, 02:04 PM   #1
Pokerob
hug life
Pokerob's Avatar
Default D70 drw - disk brake help
I have a 70-75 dodge rear D70 drw.
build date: 11 10 2a8
BOM: 603285
1971-75 M300 & P300 Motor Home & Delivery Van
603285-4 Standard 4.56 706048-3X 706082X 706084X 706085X 35091-1 35091-1
I bought this disc braket but now i see it wont work since its for a GM axle not this one.
https://www.4wdfactory.com/store/pro...7;2C-GM-Dually
anyone have any leads on what brakets i wil need?
also what disks etc, i totally f'd up with the wrong info but now cannot find any info on what works with this axle
Old January 22nd, 2011, 02:06 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
no link
Old January 22nd, 2011, 02:07 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
probably best off to buy the weld on ones
Old January 22nd, 2011, 02:13 PM   #4
Pokerob
hug life
Pokerob's Avatar
do you have a link?
Old January 22nd, 2011, 02:24 PM   #5
hosejockey4506
Visiting Admin
aa-mfg.com
Old January 22nd, 2011, 02:24 PM   #6
hosejockey4506
Visiting Admin
http://www.ruffstuffspecialties.com/...3c51e2560ed458
Old January 22nd, 2011, 03:58 PM   #7
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
A Link and good price.
http://www.ballisticfabrication.com/...ts_p_1439.html
Old January 22nd, 2011, 04:13 PM   #8
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
Id go with ballistic ones I ordered a set of disk brake brackets for my Dana 60 rear they sent me the wrong ones and wouldn't do anything about went with ballistic they were right and a lot better and nicer to
BIGDANE36 is offline   Reply With Quote
Old January 22nd, 2011, 06:54 PM   #9
Pokerob
hug life
Pokerob's Avatar
Default another problem: disk to hub
thank you guys for all the help, i am going to order some up.
Ok no i have run into the problem where the disk does not fit over the hub??
its not just the center hole its that the hub is to big for the disk to fit over the hub. I will go get a pic.
Old January 22nd, 2011, 07:06 PM   #10
Pokerob
hug life
Pokerob's Avatar
here the rotor will not fit over the hub
can i run it behind the hub? like this? i have to find different studs etc
wish i would have just found a 14b drw now
Old January 22nd, 2011, 07:33 PM   #11
Jeepaholic
Jeepaholic's Avatar
that is the way it goes on most any rear disc conversion, your drums slide on or held on by the studs? If studs you should be able to use the old ones
Old January 22nd, 2011, 07:34 PM   #12
Pokerob
hug life
Pokerob's Avatar
they just wont slide over.
either they are the wrong discs or the hubs are just to big.
the discs are
72 - 87 Chevy 3/4 Ton Rotors (front 4x4)
Old January 22nd, 2011, 07:41 PM   #13
Jeepaholic
Jeepaholic's Avatar
You have it right was asking how the drum was held on?
Old January 22nd, 2011, 07:48 PM   #14
Pokerob
hug life
Pokerob's Avatar
i never had the drums.
so the studs go through the rotors to the hub then?
i cant use the orinal studs due to them being to big for the rim. I need to use a smaller stud (front 60 size dia) so the h1 rims fit. the d70 studs are quite alot bigger.
Old January 22nd, 2011, 07:53 PM   #15
Jeepaholic
Jeepaholic's Avatar
Ya had a drw 60 with the 5/8's studs , yes studs press through the rotor just like a front 60. Check the diameter but might be able just get front studs for a chevy/dodge 60
Old January 22nd, 2011, 07:57 PM   #16
Pokerob
hug life
Pokerob's Avatar
i brought in my hub and rotor to napa and spent about an hour there looking through studs.
The only ones that are long enough that will work have too big of a shoulder for the rotors.
To make these work i will either have to turn down the stud shoulders or drill out open up the disc hole.
I am opting to opening up the disc hole.
Old January 22nd, 2011, 08:06 PM   #17
Jeepaholic
Jeepaholic's Avatar
Ya just open up the rotor holes a bit
Old January 22nd, 2011, 08:13 PM   #18
Pokerob
hug life
Pokerob's Avatar
there has to be a better way for this junk.
drilling out 16 holes so the studs fit sucks
at least i know some people who work in shops where they can just plop it on the machine and done.
Old January 22nd, 2011, 08:19 PM   #19
Jeepaholic
Jeepaholic's Avatar
Wouldn't be custom if it didn't involve work
Old January 22nd, 2011, 08:31 PM   #20
Pokerob
hug life
Pokerob's Avatar
true.
thank you for all the help, i was 2nd guessing myself on the studs holding on the disk.
now i just need to do it, take pics then post it for others.
well unless it doesnt work
Page generated in 0.39619 seconds with 83 queries
