2005 Jeep Unlimited (LJ) "Slow Roast" build - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2011, 08:12 PM   #101
Spudy
Redneck Excavator
Spudy's Avatar
Spudy is offline   Reply With Quote
Old August 29th, 2011, 09:03 PM   #102
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
The Dana 70U is now in, and it's sitting on it's own weight again. Ride height is right at 1.5" higher in the rear than in the pic below, when it was on blocks. It looks like the width (right at 65" wide) matched with the H2 wheels will be perfect once the extended AEV flares are installed.
Craig
ID:	82873   Click image for larger version
Old August 29th, 2011, 09:52 PM   #103
akozman
Chrome Trucker Chicks Rul
akozman's Avatar
Originally Posted by 1x1_Speed_Craig View Post
Front arrived...
(teaser pic)
Nice! If it doesn't have it already do yourself a favor and drill/tap a drain plug, with the diff cover being rotated like it does it absolutely SUCKS to change diff fluid (I've got those F&R in my rig). Make sure you don't tap too deep because it'll be right under the Ring gear and obviously you don't want the plug to hit the gear, there are 2 different styles of drain plugs that I'm aware of, can't remember the name of them but one is deeper than the other, get the less-deep one.
Nice build, wish my TJ was an LJ, I need a station wagon now with the family.
Edit - also if you ever need a new pinion seal contact Applied Tech, part #CR18926....WAY cheaper than autoparts or Currie
akozman is offline   Reply With Quote
Old September 27th, 2011, 05:04 PM   #104
jaymcjay
jaymcjay's Avatar
So how long till you loose interest in this project and I can buy it at fire sale price?
jaymcjay is offline   Reply With Quote
Old September 27th, 2011, 05:09 PM   #105
jaymcjay
jaymcjay's Avatar
Wow, I just posted and saw how old my profile pic is. I haven't been around for a while...
Old September 27th, 2011, 06:13 PM   #106
jaymcjay
jaymcjay's Avatar
there...that's better! :)
Old September 27th, 2011, 06:26 PM   #107
1x1_Speed_Craig
Simplify...
Noted.
Thanks for the heads-up, Koz.
Nice, Joel. Not this one. Only new vehicle EVER = Keeper.
Craig
Old September 27th, 2011, 06:37 PM   #108
1x1_Speed_Craig
Simplify...
BTW, here's an updated photo with the rear axle installed, and at actual ride height (along with Mira being a cheeseball).
Old September 27th, 2011, 06:40 PM   #109
dreezy
Haggard Fab
dreezy's Avatar
I didn't realize jack stands were so expensive until lately.
Old September 27th, 2011, 06:45 PM   #110
jaymcjay
jaymcjay's Avatar
Seriously, buy a set!
Heck, I could probably loan you a set or two for a few months...just let me know.
Old September 29th, 2011, 08:35 PM   #111
1x1_Speed_Craig
Simplify...
Front axle teaser shots courtesy of beejers at RockSolid Performance.
I want to give a big thanks to Jared at Unlimited Offroad, as he spent a good amount of time helping me figure out the specs on the Currie Iron Jock III front axle housing, and guiding me on my build plans. Thanks man!!! I purchased just the bare housing/knuckles/1-ton brakes/Ford unit bearings from UORC, as I didn't have cash to buy all the "guts" up front.
Fast forward a few months (back on the \/\/est side of the state). Big thanks to BJ and Gordon at RockSolid Performance for helping me with the gears, locker & shaft purchases, and also for powdercoating and assembling the axle. The axle is getting 4.88 gears, a Grizzly Locker, and 35-spline axle shafts.
Craig
ID:	84004   Click image for larger version
Old September 29th, 2011, 11:05 PM   #112
Mr. Beefy
BFT!
Mr. Beefy's Avatar
BLING!!! Awesome build
Old October 13th, 2011, 09:21 PM   #113
Porscheguy
Porscheguy's Avatar
updates?
Porscheguy is offline   Reply With Quote
Old October 14th, 2011, 06:33 AM   #114
1x1_Speed_Craig
Simplify...
Got some (2 sets). Thanks Joel. Thanks for the home-brew & steak last night, too. It was great catching up with you & Rob.
Thanks Mr. Beefy.
Originally Posted by Porscheguy View Post
updates?
Yes, the update is that my bank account is drained.
Actually, I have been working more on my daughter's XJ (
build thread HERE
) as of late. I'm also in a bit of a waiting game...
I planned on running a Full-Traction 3-link rear (short arm), but lucky for me (note sarcasm), the wishbone bar was a bit narrow for my frame (~3/8-1/2"). It's actually within spec according to Full-Traction, so I'm guessing it's just due to slight variances in manufacturing when my Jeep was built. Given that I ordered it in mid-May and waited several months to get it, and also this fittment issue, Jared at UORC has worked with Full-Traction to get me a great deal on a 4" long arm upgrade. We're still working out the fine details and timing. I'll run the Full-Traction skid plate & long arms (the AEV skid will be returned), and keep my existing springs.
The only thing I should need to address with the FTS long-arm set-up is an adjustable track bar. I'll probably have RockSolid Performance make me one locally.
Craig
Old October 14th, 2011, 06:50 AM   #115
beejers
always building
beejers's Avatar
If all goes well you will have a front axle to install this weekend.
beejers is offline   Reply With Quote
Old October 14th, 2011, 06:56 AM   #116
1x1_Speed_Craig
Simplify...
Don't kill yourself to get it wrapped up...without control arms to attach it to, it'll just sit and look pretty. I may even ask Amy if it can be a living room centerpiece until the Full-Traction parts get to me. Thanks again, BJ.
Craig
Old October 15th, 2011, 12:30 PM   #117
1x1_Speed_Craig
Simplify...
Assembled axle pics just in from RockSolid Performance. they just need to finish up the brakes.
Specs:
  • Currie Iron Jock III housing (66" WMS-to-WMS)
  • 4.25" axle tube diameter
  • 4.88 gearing
  • Yukon Grizzly locker
  • 35-spline shafts
  • Warn lock-outs
  • 1-ton brakes (GM rotors, Dodge calipers)
Again, big thanks to both Unlimited Offroad Centers and RockSolid Performance on their respective roles in making this axle a reality. Thanks guys!
Old October 15th, 2011, 12:49 PM   #118
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I need to stop and see this thing one of these days in person. Looks awesome.
Old October 15th, 2011, 06:52 PM   #119
1x1_Speed_Craig
Simplify...
Pics in Post 117 above should be visible now.
Old October 15th, 2011, 07:51 PM   #120
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I just got the pics of this axle setup all sticky.
dougstephvoor is offline   Reply With Quote
Page generated in 0.70528 seconds with 85 queries
