95 lost keys need to remove Ignition cylinder - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2011, 07:00 PM   #1
Jleach0696
Jleach0696's Avatar
Default 95 lost keys need to remove Ignition cylinder
i lost the key to my 95 suburban. i need to replace the ignition cylinder but the procedure requires you have the key so i dont know what to do. and the locksmiths in the area wont touch it because of the airbag or i would have it rekeyed.
Jleach0696 is offline   Reply With Quote
Old January 21st, 2011, 07:03 PM   #2
Flexin' XJ
Flexin' XJ's Avatar
1. pull the airbag
2. call locksmith
Flexin' XJ is offline   Reply With Quote
Old January 21st, 2011, 07:03 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
slide hammer just like the brothers
Old January 21st, 2011, 07:11 PM   #4
Jleach0696
Jleach0696's Avatar
Originally Posted by Flexin' XJ View Post
1. pull the airbag
2. call locksmith
3 locksmiths say they have to be certified to touch it if it has a airbag. the other 3 need the lock cylinder out to rekey it
id probably need a new column after that
Old January 21st, 2011, 07:11 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if its the factory lock then just go to a dealer for a new key cut to the vin. you will need the title in hand for proof of ownership
Yetti
Old January 21st, 2011, 07:20 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
x2 never had a problem doing it that way
Old January 21st, 2011, 07:58 PM   #7
Disturban
Disturban's Avatar
Also if the door key is the same as the ignition key then just pull that cylinder and take it in to a lock smith.
Old January 21st, 2011, 08:45 PM   #8
Jleach0696
Jleach0696's Avatar
dealerships say they dont have key info on models over 10 years old called a few dealerships
Old January 21st, 2011, 08:46 PM   #9
Jleach0696
Jleach0696's Avatar
no steering column was replaced before so dealer wouldnt have worked anyway found out the dealer thing when girlfriend lost her keys few months ago
Old January 21st, 2011, 08:56 PM   #10
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
Just replace the column. But I think a locksmith can make a key with just the ignition cylinder. You might have to have the truck towed to there shop.
spr_chicken is offline   Reply With Quote
Old January 21st, 2011, 09:00 PM   #11
Jleach0696
Jleach0696's Avatar
gonna try to get the cylinder out tomorrow and either have it rekeyed or get a new cylinder with key
if that doesn't work probably going with a new column
Old January 21st, 2011, 11:02 PM   #12
Disturban
Disturban's Avatar
If you can get the cylinder out just go to autozone and buy a new one, they are cheap and come with a key.
Page generated in 0.25457 seconds with 59 queries
