EB dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2011, 12:13 PM   #1
powerranger33
powerranger33's Avatar
Default EB dana 44
I picked up a EB dana 44 w/ drum breaks. I"m gonna be putting disk brakes on it and was wondering if i could use any year ford d44? also, i was looking at running chevy flat top knuckles and was wondering what years those knuckles came on?
powerranger33 is offline   Reply With Quote
Old January 20th, 2011, 12:15 PM   #2
Complete Off Road
Complete Off Road's Avatar
not trying to sell you a conversion kit but maybe this parts list will help you:
http://completeoffroad.com/i-132909-...n-kit-d44.html
Complete Off Road is offline   Reply With Quote
Old January 21st, 2011, 12:35 AM   #3
Pop-Tart
Pop-Tart's Avatar
Quoted from TheRangerStation...
http://www.therangerstation.com/tech_library/Dana44.htm
"Another thing to watch out for with the early Bronco Dana 44 is the brakes. 1971-1975 Ford Bronco's have drum front brakes. 1976-1977 Ford Bronco's have 11-inch disc brakes. If you end up with a drum brake Dana 44 you can convert it to disc brakes. Find a 1978-1979 Ford Bronco or a 1973-1979 Ford F-150 and get the following parts:
Steering knuckle
Brake backing plate
Caliper holder (Haynes calls this the Anchor plate)
Spindle
Wheel bearing locking nut, lock ring washer and wheel bearing adjusting nut
Caliper support key and spring
Rotor (use as a core for a new one)
Locking Hubs
Basically, you'll be needing everything from the knuckles out. You'll be replacing your existing parts with these new ones."
Info on years of various flat top knuckles.
http://77cj.littlekeylime.com/flatop_knucles.html
Pop-Tart is offline   Reply With Quote
Old January 21st, 2011, 01:09 AM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I have all the parts you need off of a 77 f150 front axle. $125
Old January 22nd, 2011, 08:37 AM   #5
powerranger33
Thanks Pop-Tart, those links helped out alot. I'll keep you in mind bigblockford79 since you are on the other side of the state, i'll see if i can find something closer
Old January 22nd, 2011, 04:26 PM   #6
BOGDOG
BOGDOG's Avatar
When I converted mine to discs I ended up using most of the parts from a 79 Blazer D44. I used Ford hubs & rotors.
Page generated in 0.23985 seconds with 41 queries
