EB tie rod flip - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2011, 06:01 PM   #1
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
Default EB tie rod flip
i just finished reaming my knuckles out for the early bronco tie rod flip. I flipped the tie rod over the knuckle and now the drag link hole is facing the wrong way. So now the draglink will not bolt up because the hole is facing the wrong direction. How do i fix this problem?
84mudder is offline   Reply With Quote
Old January 17th, 2011, 06:04 PM   #2
Freak
Wheelin the HD
Freak's Avatar
typically people run a high steer arm on the pass knuckle, but define "facing the wrong way" like, can you rotate it half a turn or did you turn the whole thing 180 degrees?
Old January 17th, 2011, 09:03 PM   #3
84mudder
84mudder's Avatar
turned it 180 degrees. It looks as if im gonna have to ream the hole out and use inserts.
Old January 17th, 2011, 09:04 PM   #4
Yes, ream it out and use the insert to install it in the manner you need it to. Run into the same problem when using chevy tie rods and doing the flip.
Old January 18th, 2011, 04:40 PM   #5
84mudder
84mudder's Avatar
it looks as if the draglink it hitting the tie rod when i turn the wheel.
Page generated in 0.13721 seconds with 38 queries
