TJ front axle build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2011, 07:09 PM   #1
wally431
wally431's Avatar
Default TJ front axle build
I want to put a stranger axle in the front of my TJ I dont want a d44 and i'd like to keep it close to my 60"wms. Cuz I dont wanna be real wide. I'm thinking try and build a 9in. or just find a dana 60 and cut it down wouldn't be too hard. Let me know what you think or what you would do. I'm planning on putting a V8 in the jeep at some point so I need something to hold up better then the dana 30, I have a ford 8.8 in the rear so that should hold up.
wally431 is offline   Reply With Quote
Old January 15th, 2011, 07:59 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Gonna be more work or money probably both but a 9" seems to make more sense. Throw a Currie hp 3rd member in there and you will have a 8.8 front and rear
Old January 15th, 2011, 08:33 PM   #3
wally431
wally431's Avatar
I dont mind the work and a little bit of money here and there isn't bad, so I guess i'm looking for a ford 9in, anyone have one?
Old January 15th, 2011, 08:51 PM   #4
Jeepaholic
Jeepaholic's Avatar
Better off with a new 9" housing, spring for a spidertrax, ruffstuff, ballistic , currie, housing.
Old January 15th, 2011, 08:55 PM   #5
wally431
wally431's Avatar
wow that don't look too bad not to expensive either, also would those axle tubes they have in the related items below that work, I've got a lot of research to do, looking for brackets that should be a couple hunderd seems like the 3rd member is gunna cost the most, but over all looks like i'm gunna start building a front axle
Old January 15th, 2011, 09:00 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
a fabricated front 9" housing will be sweet. perfect foundation for a front axle build.
real pricey though!
Old January 18th, 2011, 09:04 AM   #7
John D
John D's Avatar
Just curious, why are you anti-d44?
Old January 18th, 2011, 09:27 AM   #8
Jeepaholic
Jeepaholic's Avatar
Cause the U joints are the exact same ones in a dana 30 so what's the point? Unless you spring for some rcv's which pays for a dana 60 anyway.
Old January 18th, 2011, 10:06 AM   #9
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
A 60" wide dana 60 will be pretty tricky, especially if you plan to keep coil springs and use stock or stock replacement control arms.
The knuckles on a dana 60 are quite a bit wider than a dana 30, leaving a lot less real estate to mount those brackets, mostly on the pumpkin side.
Old January 18th, 2011, 04:09 PM   #10
wally431
wally431's Avatar
Thats what i'm seeing even with a 9in is theres not gunna be a lot of room for brackets. Jeepaholic is right about the D44 is that its not much stonger then the d30. I have a long arm lift on it so they are not stock arms. but i'm looking at this bracket that has all the mounts for the coil, the shock and the control arm mount all built in.
Old February 13th, 2011, 07:23 PM   #11
itchy
itchy's Avatar
Cause everyone acts like there gonna run KOH. You aint shit unless you have 60's under your rig these days. Nothin will hold up unless they are Dana 60's and 14 bolts. :shaking head:
itchy is offline   Reply With Quote
Old February 16th, 2011, 10:28 PM   #12
wally431
wally431's Avatar
I know I said I didn't wanna go with a d44 but I've found a set from a 78 ford d44 HP front and d 60 FF rear of course I'd have to get brackets for both and I'd prolly weld the rear spiders, but I'm wondering what you guys run as axles in ur TJs. I plan on putting a 350 in there so thats the reason for a axle upgrade
Page generated in 0.20377 seconds with 59 queries
