$295 new in 09 Traxxas rustler gas truck trade ? sold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2011, 08:53 PM   #1
newdodge
jeep life
newdodge's Avatar
Talking $295 new in 09 Traxxas rustler gas truck trade ? sold
Traxxas brand 1/10 scale gas powered, radio controlled, Ready To Run
Features:
•TRX 2.5 Racing Engine
•Ball bearings
•EZ-Start 2 electric starter
•Tune pipe exhaust system
•Double deck T-6 aluminum and composite chassis
•Magnum 281 transmission with ball bearings
•Adjustable, easy-to-change gear ratios
•X-tra long, fiber-composite, suspension arms
•Planetary differential with steal gears
•Powerful disc brake
•Telescoping, u-joint driveshafts
•X-tra long, high-volume, oil-filled Ultra Shocks
Includes:
•One TQ pistol grip radio
•One Nitro Rustler assembled with TRX-2.5 and glow plug
•One EZ-Starting System
•One Painted Body and Spoiler
•One Decals
•One Extra aluminum cylinder head gasket shim
•One Black plastic shock collar and piston
•One Extra 72 tooth spur gear
•One Antenna tube and cap
•Six 5x11mm ball bearings in transmission
•Eight 5x11mm metal bushings for wheels
•Two 5x11mm bearings for clutch
•One Extra receiver cover balloon
•One Instructions
•Composite tuned pipe
Specifications:
•Length: 17-1/4" (438mm)
•Front track: 12-1/2" (318mm)
•Rear track: 12-3/8" (314mm)
•Weight: 60 ounces (without radio)
•Height: 6"" (152mm)
•Wheelbase: 10-3/4"" (287mm)
•Wheel diameter: 2.2""
•Fuel capacity: 2.5 ounces (75cc)
•Engine: TRX 2.5 w/EZ Start System
•Gear ratio: Adjustable 8.43:1 to 12.64:1
•Differential: Planetary gear
•Brake: Disc
•Chassis: Double-decked (bottom aluminum,top composite)
•Spur gear: 72 black nylon tooth
•Clutch bell: 20 steel tooth
•Castor block front 30 degrees
•Batteries for the Controller
•7.2 volt Battery Pack (for included electric starter)
•Nitro Fuel
•After-Burn Oil
•7.2 volt Battery
comes with 3 bodys black Roll Cage
and race gas 1g batt charger 2 sets or tires and 5 sets of shocks and more i have 700 in this car runs great
trade for a rc rock crawler or subs and amp or winch or ?
newdodge is offline
Old January 13th, 2011, 10:30 AM   #2
newdodge
jeep life
newdodge's Avatar
am i to high on price it is a nitro
newdodge is offline
Old January 14th, 2011, 01:09 PM   #3
newdodge
jeep life
newdodge's Avatar
trade ?
newdodge is offline
Old January 15th, 2011, 08:23 AM   #4
LS6454
LS6454's Avatar
Alittle confused by your posting. Is it a Nitro Rustler or a Electric Rustler ?
You say its Nitro "GAS" powered in the heading but you copied and pasted the info for a Electric Rustler.
LS6454 is offline
Old January 15th, 2011, 09:05 AM   #5
newdodge
jeep life
newdodge's Avatar
Nitro Rustler yes i did i will have to fix it thanks
newdodge is offline
Old January 15th, 2011, 02:34 PM   #6
mudchucker
mudchucker's Avatar
pm sent.
mudchucker is offline
Old January 15th, 2011, 09:43 PM   #7
newdodge
jeep life
newdodge's Avatar
got it pmed back
newdodge is offline
Page generated in 0.26919 seconds with 44 queries
