Jeep Axle swap question w/arb locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2011, 07:20 PM   #1
kevsCJ7
kevsCJ7's Avatar
Default Jeep Axle swap question w/arb locker
Is a D30 from a XJ a direct bolt in to a TJ??
kevsCJ7 is offline   Reply With Quote
Old January 12th, 2011, 08:46 PM   #2
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Yes, except an XJ axle doesn't have the cam bolt set-up for alignment of the axle. You'd need adjustable lower control arms (or to weld on new LCA mounts) to do it correctly on a TJ. Otherwise, it bolts up just fine.
Craig
Old January 12th, 2011, 09:02 PM   #3
kevsCJ7
kevsCJ7's Avatar
Do you need adjustable uppers too?
Old January 12th, 2011, 09:21 PM   #4
1x1_Speed_Craig
Simplify...
No
Old April 14th, 2011, 12:41 PM   #5
kevsCJ7
kevsCJ7's Avatar
Ok, maybe dumb question but......
How about all the brake components & sway bar discos. I'm assuming it's all interchangeable but thought I'd ask.
THANKS
Old April 19th, 2011, 08:56 PM   #6
1x1_Speed_Craig
Simplify...
THANKS
You'd want to get brake calipers/rotors based on the year/model of the donor axle. There are differences, I believe. The alternative would be to swap your knuckles and all hardware from your current axle on to the HP D30.
Craig
Page generated in 0.16316 seconds with 41 queries
