MBRP Diesel Jeep 4 Door JK Truck - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2011, 12:05 AM   #141
93XJcountry
Nothing Runs Like a Deere
93XJcountry's Avatar
i am digging the 3 piece manifold, and are you guys going with compunds?
93XJcountry is offline   Reply With Quote
Old March 8th, 2011, 12:45 PM   #142
MBRP Tech 1
MBRP Tech 1's Avatar
We are using the turbo's shown in the picture on the last page. They are a compound set up. Should work very well for low end boost, yet have tons of power in the mid and high range as well. Can't wait to hear these things spooling up.
MBRP Tech 1 is offline   Reply With Quote
Old March 8th, 2011, 01:51 PM   #143
DieselJeep52
DieselJeep52's Avatar
Send a message via AIM to DieselJeep52 Send a message via MSN to DieselJeep52
sweet, always good to see another person stepping it up and putting a 12valve in a jeep. are the jk hoods that much shorter than a yj? i shoved my 12 valve in without cutting anything, running electric fans, and no intercooler though.
DieselJeep52 is offline   Reply With Quote
Old March 10th, 2011, 12:31 PM   #144
MBRP Tech 1
Couldn't tell you how much shorter they actually are, but the real issue for us is the turbo's coming in through the fire wall... This will be intercooled as well when it's done so we're going to be working in a pretty tight area to get everything to fit just right.
Old March 10th, 2011, 12:32 PM   #145
MBRP Tech 1
More updates today! The roll cage is being built for a few reasons...Both safety and to build rigidity in the frame. The roll cage is both frame, and body mounted using bushings and mounting plates. This allows us to completely remove the body, with the cage still in tack, yet it ties everything together when the body is mated to the frame. The cage is all hidden inside the custom hard top, and the freedom panels will still be completely functional and removable.
Here are a few shots of the early stages:
Old March 10th, 2011, 04:10 PM   #146
MBRP Tech 1
These pics show the extension tubes that extend forward through the cowl into the engine bay. They have slugs welded in them for attaching the engine bay structure to them and they are welded to the front side of the A-pillar vertical bars.
The crossbar for behind the dash is done and the 3rd upper cross bar is in place. Tomorrow the dash will be modified to fit back in.
Old March 10th, 2011, 04:12 PM   #147
MBRP Tech 1
Twins are in place. Not set completely, but in place. A little different mounting location especially for the lower (primary) turbo would be nice for fitment of the turbo itself as well as the down pipe, but it can be made to work. We're still playing with some ideas to maximize room in the passenger foot well area at this point...
Old March 10th, 2011, 04:34 PM   #148
79cj5crazy
Blowin shit up since 1976
79cj5crazy's Avatar
That thing is bad ass...are you going to make a removable B-pillar protection bar? For when the doors are off on the trail, they did a cage recently on extreme 4x4 and it looked like a good idea, pretty vulnerable spot.
79cj5crazy is offline   Reply With Quote
Old March 10th, 2011, 06:16 PM   #149
hellspawn
hellspawn's Avatar
look's nice
hellspawn is offline   Reply With Quote
Old March 10th, 2011, 06:23 PM   #150
boggin-machine
boggin-machine's Avatar
looks like shit....... ill come get it now. be there in a few hours with a trailer....
awesome job guys!!!! looks great!
Old March 11th, 2011, 08:47 AM   #151
babyjp95
average guy
babyjp95's Avatar
I no you hear this a lot but you guys are doing an awesome job and I wish I had your job! Keep up the great work
babyjp95 is offline   Reply With Quote
Old March 11th, 2011, 05:04 PM   #152
Alex
Alex's Avatar
Alex is offline   Reply With Quote
Old March 14th, 2011, 03:00 PM   #153
k5jess
k5jess's Avatar
Outstanding
k5jess is offline   Reply With Quote
Old March 14th, 2011, 03:53 PM   #154
pistol pete
I do vinyl stickers
pistol pete's Avatar
cant wait to see some axles and tires under it...
pistol pete is offline   Reply With Quote
Old March 16th, 2011, 06:56 PM   #155
MBRP Tech 1
More updates...The front seats were put in place to check clearance and room around the roll cage. The mounting hardware is all getting replaced with some new hand fabbed stuff, but we wanted to make sure everything fits comfortably.
The roll cage has also been extended to run down the B pillar, and as you can see, mounts to the floor, and also ties into the frame.
The axles have shipped from Currie I'm told and we should see them in a day or two! Things should get moving once these come in!
A few shots of the progress:
Old March 16th, 2011, 07:23 PM   #156
Pino
Pino's Avatar
looks great keep up the good work
Pino is offline   Reply With Quote
Old March 16th, 2011, 10:38 PM   #157
BlueBlazer98
Winning
BlueBlazer98's Avatar
awesome work! when do you plan on this being ready by?
BlueBlazer98 is offline   Reply With Quote
Old March 17th, 2011, 07:49 AM   #158
hellspawn
hellspawn's Avatar
Nice work
Old March 17th, 2011, 09:10 AM   #159
MBRP Tech 1
Likely going to be early spring. Hard to say right now because we have a lot left to do. Suspension is going to take a few weeks minimum, and there are still tons of little details yet to be addressed.
Old March 17th, 2011, 09:27 AM   #160
MBRP Tech 1
A few teaser pics with the 44" Pitbulls under it!
Page generated in 0.47045 seconds with 84 queries
