MBRP Diesel Jeep 4 Door JK Truck - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2011, 11:10 PM   #121
wadshrp
wadshrp's Avatar
Originally Posted by jbsjunk View Post
#1 Or some variation of it.
The others look blah on that.
x2 good work though keep it up
Originally Posted by clarkstoncracker the d-bag View Post
I'll trade you my trail rig for the front wheels off your joe dirtmobile.
Originally Posted by chadcooper55 View Post
Hi steveo, this is chadcooper55. I like long walks on the beach and I can take two dicks in my butt at the same time. Want to go out some time?
wadshrp is offline   Reply With Quote
Old February 7th, 2011, 10:14 PM   #122
branch92
Only in a jeep
branch92's Avatar
updates??
branch92 is offline   Reply With Quote
Old February 8th, 2011, 04:34 PM   #123
MBRP Tech 1
MBRP Tech 1's Avatar
Another forum member asked us how we planned on removing the valve covers for valve adjustments...Here is the latest.
The pictures below show a removable cross member that will allow us to lower the motor in the jeep to remove the valve covers etc with out pulling the motor. We're hoping to have this cross member in place by Thursday. Should have more updates by then.
MBRP Tech 1 is offline   Reply With Quote
Old February 8th, 2011, 09:29 PM   #124
green50gt
Got rocks?
green50gt's Avatar
How did I miss subscribing to this! Awesome.
I heart Jeeps
green50gt is online now   Reply With Quote
Old February 14th, 2011, 04:08 PM   #125
MBRP Tech 1
The engine cross member has been welded into the frame, and we were able to get the dash installed to see how much room there really was to work with. There is obviously a lot less room under there than there used to be but it looks like we should be able to keep this looking very clean once everything is boxed in.
We also got our clutch master cylinder from South Bend, and they are going to be installing it shortly as well. We want to make sure there is still lots of room for the pedals etc.
Here are a few pictures of the progress made under the hood:
Old February 14th, 2011, 04:33 PM   #126
hellspawn
hellspawn's Avatar
looks good keep up the good work
hellspawn is offline   Reply With Quote
Old February 14th, 2011, 07:19 PM   #127
uncledick
Kreepy Krawlerz Off Road
uncledick's Avatar
hurry up, only a few days till its unveiling at Dogparty!
uncledick is offline   Reply With Quote
Old February 14th, 2011, 07:42 PM   #128
trailrail302
Im going FAST!!!
trailrail302's Avatar
Looking good !!!!
trailrail302 is offline   Reply With Quote
Old February 15th, 2011, 10:33 AM   #129
alumitub78
alumitub78's Avatar
Awesome idea with the crossmember! It looks terrific, also I think it's so cool you guys are keeping it a manual transmission. Getting to row through the gears in that jeep will be an experience for sure!
alumitub78 is offline   Reply With Quote
Old February 17th, 2011, 04:37 PM   #130
hellspawn
hellspawn's Avatar
Any updates?
Old February 25th, 2011, 03:32 PM   #131
MBRP Tech 1
We had a few more parts show up this week, and the work continues on getting the body ready for the motor and suspension. We are currently working on the new cage, and will be fabricating the rear section out of heavy gauge 2" tubing. The roll cage and roof rack tube diameter will both be the same outer diameter to give it a uniform look.
We received a bunch of stuff from BD Power this past week...ARP studs, Killer dowl pin, 60hp injectors, delivery valve kit, and a number 5 fuel plate and we will be working on the motor over the next few weeks. Turbo's should be on their way shortly as well...
Big thanks to Autometer for stepping up with all the gauges required to monitor everything going on with the Cummins.
We have also got the Atlas 2 speed transfer case...
A few pictures of the progress:
Old February 25th, 2011, 04:53 PM   #132
MiNi Beast
MiNi Beast's Avatar
yeah iits taking form now, looking good. Love that atlas you adding.
Old March 1st, 2011, 06:50 PM   #133
branch92
Only in a jeep
branch92's Avatar
i really like this thing .. anymore updates?
Old March 2nd, 2011, 10:47 AM   #134
MBRP Tech 1
Work on the cage is going well, and it is beginning to take shape. The reinforcement will help make this Jeep as safe as possible, while still maintaining clearance under the hard top.
The Pitbull Rocker 44" tires also came in today. Can't wait to see them stuffed under the body for a teaser pic. Big thanks goes out to the guys at Pitbull... Tires are 44/19.5/20. With the wide and aggressive tread pattern these tires should perform well in most trail conditions and some street driving as well.
Old March 4th, 2011, 10:06 AM   #135
disturbedsledneck
disturbedsledneck's Avatar
Awesome build!
Subscribed.
disturbedsledneck is offline   Reply With Quote
Old March 4th, 2011, 10:12 AM   #136
trs80
Square Bear Killer
trs80's Avatar
Tire envy!
trs80 is offline   Reply With Quote
Old March 4th, 2011, 11:02 AM   #137
MBRP Tech 1
The turbo's came in this week, as well as the power tank. BD Diesel has stepped up with a set of compound turbo's that are really going to give us the added boost in performance we're expecting out of this 12 valve. The 3 piece manifold will also help minimize any heat deflection or issues that surround the factory manifolds on the cummins engines...
The power tank will be mounted to the rear section of the new cage once it's complete. Here's a few pictures:
Old March 4th, 2011, 03:04 PM   #138
paul keehl
paul keehl's Avatar
can't wait to see this thing on all four. but dam it is bad ass
paul keehl is offline   Reply With Quote
Old March 4th, 2011, 04:29 PM   #139
hellspawn
hellspawn's Avatar
Sweet
Old March 5th, 2011, 10:51 AM   #140
disturbedsledneck
Very nice!
Page generated in 0.70675 seconds with 84 queries
