46 oil p.s.i. problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2011, 09:09 PM   #1
joshcorey56
Default 46 oil p.s.i. problem
i have a brand new 460. new high volume oil pump. and it has the roller cam bearings so they closed off the valley oil ports. was wondering if i need to use a 3/8 inch oil line to get the wright pressure reading. thanks
joshcorey56 is offline   Reply With Quote
Old January 11th, 2011, 09:34 PM   #2
camccardell
tiger blood
camccardell's Avatar
46psi is too high?
Old January 11th, 2011, 09:46 PM   #3
bobbywalter
asshatt
bobbywalter's Avatar
3/8 will not change the psi reading unless its leaking oil out of it.
not having spec'ed and assembled the engine i could not guess positively at what the psi range should be.
46 warm on a fresh build is ok though "generally" speaking.
bobbywalter is offline   Reply With Quote
Old January 12th, 2011, 09:44 AM   #4
Bones
Bones's Avatar
so what is the problem?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 12th, 2011, 09:49 AM   #5
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
Anyone consider he meant to type "460 oil psi problem" I don't think he'd be complaining about 46 psi
MISHOWJEEPER is offline   Reply With Quote
Old January 12th, 2011, 11:15 AM   #6
littletrucker
I'd hit that
littletrucker's Avatar
I think we need more information about the problem then
Old January 12th, 2011, 11:47 AM   #7
Bones
Bones's Avatar
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 12th, 2011, 11:48 AM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I don't get it
H.o.r.e
Old January 12th, 2011, 11:53 AM   #9
MISHOWJEEPER
NSFW
Who the hell knows, the op sucks at describing his problem, that's all I was pointing out
Old January 12th, 2011, 09:03 PM   #10
joshcorey56
the oil wont go up the line to the gauge. but when i take the line off it comes out fine. all holes are clear in the fittings and i can blow through the line. heiges said to run a 1/4inch copper line because all the valley ports have been closed because of the roller cam bearings.
Old January 13th, 2011, 11:48 AM   #11
IDIeselman
IDIeselman's Avatar
I get the distinct impression that your engine builders don't know what the hell they're talking about! If I read your post correctly, they've completely shut off the oil flow to the rods, and mains in your engine! Did they install the correct "pointed" threaded plugs in the front, and the standard NPT plugs in the rear of the block? Did they plug the oil gallery's in the "tower" in the tappet chamber, if so - then they've probably "pre destroyed your engine"!! DO NOT RUN IT AGAIN until you / they resolve this issue! I bet they told you that they've built plenty of "record setting" Chebby's!
I'm watching you.
Old January 13th, 2011, 01:34 PM   #12
Bones
Bones's Avatar
if the oil won't flow through the line to the gauge, then there is no oil pressure going into the line. Period.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 14th, 2011, 12:00 AM   #13
joshcorey56
my dads buddy came over and out of the blue he looked down in my distributor hole and saw there was not a plug in the front of the motor so it wasnt going all the way to the back of the motor and just going back down to the front. i figured if i spend 600 bucks to get my block done they would replace them after they take them out you know? my motor now has 80 p.s.i. oil. tim you kind of nailed that one on the head.
Page generated in 0.26014 seconds with 62 queries
